Moser 9" yoke size
Moser 9" yoke size
Does anyone have any Spicer info?
I bought a roller with a Moser 9 in it. The yoke has "SPICER 59" stamped on it. I found a large download from Spicer but could not find anything referencing "59". I'm trying to find out what u-joint and straps I need for this.
I sent pictures to Moser of all the markings I could find on the rear hoping they kept a log of what they built. No luck with them.
LS1Tech Sponsor
1310 Spicer Series: 1 1/16″ Cup Diameter (Dim C – Diagram A) 3 7/32″ length (Dim B – Diagram A) Certain Ford applications have 2 cups 1 1/8 Diameter. Appropriate horse power range is up to 500 in circle track or road racing, small tire drag racing and 4×4. Also available: Performance Dynamic Cryo Joint.
1330 Spicer Series: 1 1/16″ Cup Diameter (Dim C – Diagram A) 3 5/8″ length (Dim B – Diagram A) Certain Ford applications have 2 cups 1 1/8 Diameter. Slightly stronger than 1310, Used in 5.0 Mustangs. Also available: Performance Dynamic Cryo Joint.
3R Saginaw Series: 1 1/8″ Cup Diameter (Dim C – Diagram A) Retained with internal clip 2 5/8″ (Dim B – Diagram A). Most common GM joint. Horse power range up to 700 in road racing and circle track. Solid drag racing U-Joint can accomodate most sportsman classes. Also available: Performance Dynamic Cryo Joint.
1350 Spicer Series: Manufactured with OEM tolerances and treated with our Cryogenic Process to yeild the strongest U-Joint available. For drag racing applications a solid non-lube design U-Joint is recommended because of the tremendous initial shock load, or short duration of high torque the joint must be able to withstand.
How tight should I tighten my u-bolts?
1310 series and 1330 series should be tightened to 17 ft/lbs and 1350 series to 20 ft/lbs. You should never tighten the nuts on any u-bolt excessively. This will cause the cap to distort and the u-joint will fail prematurely.
Hopefully this helps. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Thanks Bob. That's some good info.
Is the 1350 larger than either of those? I measured roughly 1 1/4" on the machined surface of the yoke where the cups sit.
I also measured roughly 3 3/4"" on the width. Again rough measurements with a tape measure on the yoke.
LS1Tech Sponsor
When I order 9 inch rears I always have them come with 1350 yokes, but not everyone does so you'll indeed need to confirm what yoke size it has. Bob
__________________
LS1Tech Sponsor
I don't carry the U Bolts, you should be able to source them at a local Napa or you could call over to Moser at 260 726-6689 and ask for Foz.
Thanks. Bob
__________________
LS1Tech Sponsor
You're welcome, thanks. Bob
__________________
