K&N Air Filter - question
I run that filter but wash it in Dawn's dish soap and don't re-oil it.
I definitely will not be replacing it for $135 lol. Also do not know of any knock off replacements either
I run the K&N panel style filter, still have the MAF, and have never had a single issue. A lot of the issues come from improper oiling of the filter. If done correctly it shouldn't be a problem
Even when oiled perfectly.......the first time you drive in the rain, through fog, or just get a splash of water in there......that perfect layer of oil reactivates and immediately goes right onto the MAF sensor wires. You may not feel a big change....but a dirty MAF is absolutely robbing you of some performance and WOT throttle response. The wetter the filter gets.....the worse the performance gets over time. Until the MAF is cleaned again.....
Also, a paper filter is many times better than a K&N for stopping dirt. Also, power gains from K&N filters are all dyno tricks. They never show any power gains if done independently.
Not saying the K&N kills an engine or makes it stall out.....
Save the manuals!
If you search google for "car air filter dimensions" you should get some resources from other filter manufacturers (like K&N) has, which will allow you to find filters for custom applications.
I ruined my KN .....yes to MUCH water pressure while cleaning WILL tear the cotton element
I am looking for a replacement too
this KN p/n is a universal part and not a direct drop in it looks like for the f body kit....missing the front threaded hole and rear temp sensor hole
in the pic in the first post, there is a threaded hole in the front.
i cant find any pics for the back, but since its a K&N,
i'd assume it would have the hole in the back for the temp sens.
