Scraping my cx racing intercooler. What's next?
Old 08-18-2017, 11:17 PM
chvycmaroz28's Avatar
Default Scraping my cx racing intercooler. What's next?
After chasing 175° Iat on 8th mile pass with 93/meth I did some testing and learned that my CX has a 10 psi pressure drop. What's out there for a good price that will support 900-1000whp. I know bell and Garrett are good but those r expensive
Old 08-19-2017, 12:26 AM
Nitroused383's Avatar
How much are you willing to spend? I had a custom a2a made with a garrett core that was well worth its price. I went from a 75 degree temp rise on 15 psi to about half of that on 20 psi in the 1/4.
Old 08-19-2017, 01:29 AM
silvea's Avatar
Have you contacted Huron speed? I'm sure their race intercooler is much higher quality at a fairly good price. Ask Denmah about the vs race intercooler he's used a few with good results.
Old 08-19-2017, 03:22 AM
I would like something I can grow into if possible. However I can't justify spending $1000+ for and intercooler when my motor was only $300. I have heard good things about the treadstone 28x12.5x4.5
Old 08-19-2017, 03:26 AM
I believe the mishimoto, vs racing and cx racing r all the same core's
Old 08-19-2017, 05:15 AM
silvea's Avatar
This may be true I don't keep track of who makes what intercoolers. CX racings intercooler was pretty decent when I used it on my SRT4. I used it on the stock turbo and a 50mm turbo and it held up pretty well. Then after my wastegate reference popped off and my 50 trim went ******* haywire and over boosted from 26lbs to 43lbs and I fucked up my ring lands I went with a fully built engine. Everything you could imagine and some shady **** you wouldn't even dream of (legit strapped one side of the block to the other in the oil pan off the mains to keep the block from expanding). I threw a 6262 on it and pushed the boost up to 31lbs. It became a monster and the CX racing intercooler was junk on that set up. I went with a mx racing intercooler and all was happy in the world again. Not some huge name brand but a company that specializes in SRT4's and new what a high performance intercooler needed. Now I'm on the LS platform and Burpn speed is that company. I have full faith that if you call them and explain your needs they will without a doubt tell you what you need whether it's their intercooler or not.
Happy boosting!!!
Old 08-19-2017, 06:34 AM
forcd ind's Avatar
I always wondered if the actual cores were diff from a cheap core to an expensive one-is the design that much diff, to promote good airflow plus better cooling.
A few years ago I had a Procharger sheetmetal IC'er I used on an LS with a blowthru carb, as I remember it was like 1 psi loss at around 12 lbs. I remember doing some testing on another car, off brand IC'er, temps out of the Procharger were 330 degs, knocked down to 190 @ 18 psi after the IC'er.
In 40 deg temps last year, I made a couple passes with my turbo Buick, Treadstone 25 IC'er, IAT's were in the 140-150 range. I never checked psi loss, would have liked to. I kind of wonder if you have a large pressure drop, rem. the IC and reducing the boost to the same level you were getting the temps would drop just based on the comp. having to comp. less to get that boost. I would guess a turbo makes more heat than a Procharger, at least on low boost, might even out on higher boost. OK, to much coffee already, lol
Old 08-19-2017, 07:19 AM
simple's Avatar
Treadstone has high quality intercoolers that don't break the bank.
Old 08-19-2017, 10:43 AM
2muchboostNY's Avatar
X2 for Treadstone. A bit more expensive but wont break the bank. Have used them on every build with the exception of one and have no complaints.
Old 08-19-2017, 11:28 AM
93hatch's Avatar
I bought a blemished core 24 12 4.5 garret and am into it $550 camp ebay
Old 08-19-2017, 01:16 PM
3 window's Avatar
Another for the Treadstone.
Old 08-19-2017, 01:58 PM
stevieturbo's Avatar
There are huge differences between cores and multiple core designs.
This is now a very old article, but still good info. It doesnt cover really modern stuff like Garrett units, which are truly superb.
http://www.are.com.au/techtalk/intecoolersMR.htm
If you can afford a Garrett and they do a size that fits, then go for one.
If not, Bell, Treadstone etc offer cheaper stuff. Where the Garrett excels over the others is not so much how they flow for any given size...but also how well they cool. So if it is a low boost, low heat setup, then using those cores may not be as important and a cheaper Treadstone etc would be quite fine.
Old 08-19-2017, 02:04 PM
They're a little less than that new anyway ? can be cheaper than this on ebay ? If that size would work for the guy...buy the core and weld it onto his old end tanks after cutting them off.
http://www.atpturbo.com/mm5/merchant...egory_Code=INT
Treadstone, similar size to the generic units
http://www.treadstoneperformance.com...cooler++1000HP
Old 08-19-2017, 02:06 PM
I see what ur saying. The fact that my pt88 was making 30lbs through a cx racing core and although temps were really high they weren't so bad to where I think that once pressure drop is under control to say 2-3psi and the better cooling of something like a treadstone I think I will be ok with not spending $1500 on a core
Old 08-19-2017, 02:10 PM
93hatch's Avatar
550 with endtanks lol core was like 150
I've been looking at this one http://www.treadstoneperformance.com...1245-28+1200hp
Or maybe the 6" 1300hp one if I can fit it. Either way I'm going to have to have bungs welded on top to mount it and change up my cold side a little
Old 08-19-2017, 02:22 PM
I cant even imagine where you'd find a core at $1500 to even spend it !
And if you can go big....there are rarely any downsides ( other than it may impact on radiator cooling a little more if that is a concern )
Old 08-19-2017, 02:31 PM
Part of me wants to stay away from just a core bc idk anyone who can weld the ends on
Old 08-19-2017, 02:45 PM
Then just buy the Treadstone
Old 08-20-2017, 01:36 AM
Alright thanx. I see maperformance.com has them for $450 shipped I'll order tomorrow. It's rated for 1200hp Just hope it's legit
Quick Reply: Scraping my cx racing intercooler. What's next?
