bolt ons, ls6 cam, nitrous = 10s
Took me all day today, but I finally got my first 10 second pass. Made 8 passes at Milan's No ET event. It was 80 degrees and I'm positive I could hit 10s in cooler weather on a 100 shot. First 2 were on a 100 shot and were 11.13 and 11.10 with 1.55 60's. 3rd pass I spun to a 11.35. 4th was a motor pass because I ran out of nitrous - 11.74 @ 113 on taller 28" tires. Filled the bottle, tossed in the 150 jets, go 1.51 60' then ride the limiter after first gear. I think the SS4000 can't handle 150 so I put the 100 back in. Go another 1.51 60' and ride the limiter again. Realize I forgot to put the shifter into D3 after doing my burnouts in D2. GRRRRR. Go back up, and the temp seems to be going down a bit. Go 1.53 60' and 11.04 @ 122. Toss the 150 jets in for one last "make it or break it" pass. Go 1.49 60' and 10.88 @ 122.45. Of course my phone and go pro are dead so I didn't get it on video . Trans has a delayed 2-3 shift in d3 on nitrous. I did make a pass in OD and it was much better, so I'll have to look into it.
11.10 pass inside
11.10 pass outside
11.10 pass inside
11.10 pass outside
Current race weight is around 3300. Mods are in this thread:
https://ls1tech.com/forums/11-second...l#post19727016
Only changes are 28" tire (MT ET Street Radial Pro 275/60r15), nitrous, and half tank of 93/ leaded 110
Thank you Sir! Definitely embarrassing. I was so anxious about the spraying 150 the first time that it slipped my mind. Hit the top of first and the car breaks up popping and banging. I'll post a couple videos, lol.
Here are the videos of me leaving in D2. Both 1.51 60' and both would have been 10 second passes.
150 shot:
In-car:
100 shot:
In-car:
150 shot:
In-car:
100 shot:
In-car:
No issues with the nitrous. I just don't have my setup ironed out.
The car shifts at 6400 1-2 and 6500 2-3. On 100, I had the window switch set to 6300. 1-2 shift was clean and the nitrous was off for .4 seconds while the engine took it from 6300 to 6500 to make the 2-3 shift.
On the 10 pass, I lowered it to 6200 (scaredy cat, I know lol). 1-2 shift was still quick because it goes by so fast, but the motor took 1 full second (hp tuners log) to go from 6200 to 6500 for the 2-3 shift. Then the nitrous shut off about 1 second before the finish line when I hit 6200 again. Not sure how much et I'll gain, but it will gain some mph by raising the limit and getting the 2-3 to happen sooner.
I borrowed these from a friend whose car goes bottom 10s. I think he goes mid low 1.4 off a transbrake and 200 shot in a 3600# car pulling both wheels.
Oh, they're 3 years old. I'm sure a new set would do even better. My next tires will be the 28x9 pro bracket radials on my centerlines.
