Aluminum valve cover pcv options.
Old 10-17-2017, 06:53 PM
Robert Cantu's Avatar
Exclamation Aluminum valve cover pcv options.
Ok guys as the title states I have a 02 WS6 with fast intake and ls6 pcv conversion. Now my question is if I run a catch can do I need a valve cover breather or no for these aluminum valve covers?
Old 10-18-2017, 12:21 PM
Nobody running aluminum valve covers, tought this would be simple. Any opinions.. Im thinking maybe no breather on them remember I have LS6 pcv conversion in valley pan already just adding aluminim valve covers with a catch can.
Old 10-18-2017, 01:31 PM
ANYONE running an LS has aluminum valve covers. ALL LS valve covers are aluminum! You REALLY don't know what you are working with do you???
Old 10-18-2017, 01:42 PM
BudRacing's Avatar
You should also know that you don't run breathers AND a PCV. It's either one or the other. If you're running breathers with the PCV still connected to the intake you're effectively pulling in unmetered air.
Take a look at this thread for general PCV routing methods.
https://ls1tech.com/forums/generatio...fo-needed.html
Old 10-18-2017, 04:37 PM
Ok yea thats what I was thinking and I meant aftermarket tall aluminum valve covers not factory.
Old 10-18-2017, 05:12 PM
From the looks of those will I have to tap my valve covers for hoses??? Last image ls6 pcv with catch can.
Old 10-19-2017, 12:04 PM
BudRacing's Avatar
I'm assuming your valve covers have an oil fill cap. If so, that can be drilled and tapped for a fresh air inlet a little easier than the cover itself.
Old 10-19-2017, 01:04 PM
Yes they do on pasenger side so route like this would be good.
Old 10-19-2017, 02:40 PM
nj02z's Avatar
What if you run a 4150 style throttle body,what would you do with the clean air side?
Old 10-19-2017, 03:08 PM
BudRacing's Avatar
https://ls1tech.com/forums/generatio...32-ok-pcv.html
Old 10-19-2017, 05:27 PM
SlasherVRGR's Avatar
If you run speed density you can run a breather and PCV. The breather is the "clean" air side and the PCV still acts as the dirty side.
Old 10-19-2017, 06:41 PM
nj02z's Avatar
Thanks. That is what I need I need to do. I am in Speed Density. I will put a small breather on the clean side. I do not have that style valley cover that is in the diagram.
Quick Reply: Aluminum valve cover pcv options.
