Dyno Results H/C/I Camaro
Hey guys so I finally got some quick dyno numbers for my car. Set up is on a stock bottom end ls1 346ci btr stage 4 235 242 621 590 texas Speed stage one ported 243’s fast 92 Nick Williams 92 ftp 98mm lid 85 mm gm maf Texas speed 1/78 heads and there true duals 42 lb injectors racetronix fuel pump and a yank 4000 stall and a 2.73 gear it pulls pretty good on the highway Car made 416 and 383 on just a quick tune afr was arounda 12.3 12.5 and I believe it was 27 degrees of timing. My question is do you guys think there’s more let in this set up as far as power if you or someone you know has this set up or similar please let me know what kinda power your car made
Received 1,835 Likes
HCI is right. See how it runs at the track.
The 85mm maf might be holding it back a little. Just cause it’s smaller than the throttle body.
You didn’t say what CR. If it’s in your sig it’s not showing on my phone. Anyway - yes there probably is more in it, but it likely has more to do with intake and exhaust than the mill itself.
I see the details now. They didn't pull up originally lol. That stall probably isn't doing you any favors on the dyno. Like others have said, dyno numbers are everywhere. You could have driven the car straight to another dyno and picked up 20hp. Go see what she traps and report back đŸ‘
I had a similar setup except it was a 228r cam/ 11.1 compression (243s milled)/ M6. It made 430rw/396rw. I thinks its right where it should be for an automatic. Now its time you look at some power adders lol
Would Stage I TSP 243 heads be holding it back? If not, those heads are way better than I thought!
Car trapped 121-122 mph through a 4000 stall hitting the limiter on the 1-2 and the 2-3 shift every pass. (Transmission let go the following weekend on the street ). Not a doubt in my mind I will trap 124+ mph in the spring after I rebuild my transmission with the setup in my sig.
Op should run it and see where he is at.
Forgot to add to this to my above post:
At a random car event they had a dyno you could make a couple pulls on for $50. So I did it, maybe get a happy dyno number for garage wall art.....Nope lol. I made 396 whp on a hub loaded dyno and they spun it to 6700 rpms where it made 396 whp with the setup in my sig. What I'm saying is it's just a dyno, run it and see if it traps good.
Just to drag this out again; dyno numbers should NEVER be taken as absolutes, ONLY relative to each other. Baseline, then whatever you do to it. ALWAYS on the same dyno, or any comparison is not a fair one.
Only if this was always normal....
