T4 Turbo supporting 1200-1500 WHP???
Old 10-19-2017, 03:57 AM
liketowork's Avatar
Default T4 Turbo supporting 1200-1500 WHP???
Hey Guy Is there a T4 Turbo that on a built LSX with adequate fuel will support 1200 to 1500 Wheel Horse Power? if so what brand, model, trim, and AR Thanks
Old 10-19-2017, 03:58 AM
liketowork's Avatar
single turbo set up
Old 10-19-2017, 06:40 AM
ddnspider's Avatar
Why does it need to be a T4?
Old 10-19-2017, 06:44 AM
SLOW SEDAN's Avatar
People have leaned on the Precision 76/85 and 86/85 with good results. Pricey though...
Old 10-19-2017, 07:05 AM
Cesarbambam's Avatar
might want to look into the promod series precision turbos 91mm+ etc
Old 10-19-2017, 07:21 AM
liketowork's Avatar
The car is together I am swapping the original LS1 that has cam and heads for a full forged solid roller cam engine. It is also a tight for space front mount kit
Old 10-19-2017, 07:22 AM
liketowork's Avatar
I was just on there website I was looking at the T 80 thank you.
Old 10-19-2017, 07:58 AM
2JZFC's Avatar
Do a search on Stock48. He did it.
Old 10-19-2017, 08:21 AM
forcd ind's Avatar
What's your ET goals, or do you just want a number
As said, Stock48 has made power, something like 8.19 in the 1/4, running
in the 160's, I thought he used a 476 turbo on stock innards.
Old 10-19-2017, 08:43 AM
liketowork's Avatar
Somewhere in the 8s. I use to run true Street in a mustang with a nitrous SBF that went 9.60s I want a 8 sec car
Old 10-19-2017, 10:11 AM
1CAMWNDR's Avatar
Billet S480 with biggest turbine you can get with a 1.25 A/R T4. No idea if it will get you 1200+ WHEEL hp, but it should get you into, or very close to 8s with the right vehicle and supporting mods.
And there is a mountain of difference between 8.99 and 8.00....
Old 10-19-2017, 10:24 AM
Bbcpoweredz28's Avatar
Wouldn’t some box stock s366s get him there.
Old 10-19-2017, 01:02 PM
gnx7's Avatar
Call Precision or Forced Inductions (Jose). Prepare to spend $2K+
Old 10-19-2017, 01:44 PM
SLOW SEDAN's Avatar
True the power is relative, you can run mid 8's in a 3700lb vehicle with 950whp if its reasonably setup to drag race.
Old 10-19-2017, 09:56 PM
dang, my bad. Just saw the big single post. Ya billet 80 at least.
Old 10-20-2017, 04:01 PM
a-low's Avatar
vs racing has a t4 80mm/88mm turbine its suppose to do 900 rear
Old 10-20-2017, 09:37 PM
TT427's Avatar
Mighty Mouse had been mid 8 with his Trans Am and GT91, think when he sold it it the then new owner had dynoed over 1000whp through a 400 or 80e.
Old 10-20-2017, 11:08 PM
6 Second Club Moderator
LASTLS1's Avatar
Call Forced Inductions. He built me a KILLER set of 76's.
Old 10-21-2017, 06:56 AM
silvea's Avatar
I think its going to be hard to hit your HP goals with a T4 turbo. You'd need to figure out how to get a T6 in there or a set of like T3 twins. Those T3 twins are pretty small comparatively and might be easier to fab up and make your goal for HP. I'm thinking like Comp turbo's 6262. That level of power is quite a bit extra for a 8 second 1/4 mile.
Old 10-21-2017, 07:30 PM
liketowork's Avatar
The original post was done in question form I do know where I can get a T6 to T4 adapter and it's looking like that's the route I will go the car is together but I am swapping out the engine for a forged one with solid roller cam I have a methanol kit just want to buy one time when I upgrade from what I have now. I am doing twin t3/t4 on my BMW swap But I won't push it past 600. The Camaro is more of a race car
Quick Reply: T4 Turbo supporting 1200-1500 WHP???
