Connecting wideband to standard hp tuners
Hey guys, I've been looking for videos on how to do this, I found an old one and followed the steps but it didn't work. Does anyone have a more recent link I could use? Preferably with minimal steps cuz I'm a total noob. I also thought I heard somebody say I could send my cable to hptuners and get it upgraded for $150, does anybody know if this is true? Thx
Also look at Ed Mowton's video on You Tube, it's fairly straight forward how to set up the software.
Be advised, if you're running a 2000 vintage 0411 PCM load from a Silverado, the A/C doesn't have a pressure sensor. You can use the link that JoeNova posted, just have to make sure you use the correct pin on the PCM.
Restricted User
The old PCMs still use Red connector pin 14 as a 5v input, even if they don't have A/C from the factory. You can still use it exactly like any other PCM with no differences at all. You can also use EGR, fuel tank pressure, and Tank1/Tank2 fuel level as 5v inputs.
Joe - thanks that was part of my issue - videos i found were older versions
squared - i watched that video a million times and only got halfway through the process. After reading joes link and watching your video again it finally clicked ( i think ) lol.
I have the input setup
i created the error
and the afr is on my scanner screen now, i hope to check it out on the car shortly. Thank you both
lsx power - which wideband would you suggest ? I have an aem but maybe i'll get rid of it if it would make my life easier
i created the error
test the input
You can verify the input by connecting the positive pole of a 1.5v battery to the wire that connects the O2 sensor to your PCM and grounding the negative pole. The reading on the scanner should approximate the AFR that correlates to the battery voltage based on your equation.
i created the error
i created the error
Most newer aem have serial out I beleive. The last one we had here was a blue wire going off memory.
