Another Gen6 LTI H/C SBE build w/ track times. 588/528rw
Old 01-07-2018, 07:14 AM
Pray's Avatar
Default Another Gen6 LTI H/C SBE build w/ track times. 588/528rw
I got another build finished up. This one has my STG 2 cam in it. Car is a 2016 Camaro 2SS A8.
The track pass was made in +100 DA with a 10-15 mph head wind. I was also having trouble getting the trans to take commands. There may be a rebuild in the future. I know the car had 10.20's in it. The best 60ft was 1.43 and the 10.45 is the H/C SBE Gen 6 record.
Mods:
My ported Heads
My ported MSD/TB
My STG 2 cam kit
Kooks 2" headers w/ stock cat back
Roto-fab w/ Dry filter
Circle D 4C
E85
My tuning
Another Gen6 LTI H/C SBE build w/ track times.  588/528rw-h-c-6th-gear-ervin.jpg
Another Gen6 LTI H/C SBE build w/ track times.  588/528rw-ervin-10.45-pass.jpg
Old 01-07-2018, 08:22 AM
NAVYBLUE210's Avatar
Location: Coast of San Mateo County Between Pacifica & HMB
Congratulations Awesome Results!
Old 01-07-2018, 09:02 AM
sxc Z28's Avatar
Good job! No headwind would've been 130+ trap
Old 01-07-2018, 09:49 AM
Darth_V8r's Avatar
Received 1,835 Likes on 1,145 Posts
Damn pray! You're killing these LT1 builds!
Old 01-07-2018, 09:51 AM
Received 3,018 Likes on 2,349 Posts
I thought LT1's were Gen 5...
Old 01-07-2018, 02:21 PM
Pray's Avatar
Gen6 Camaro. But yes, the new LT1 is technically a Gen 5 motor. But I have never hear of anyone refer to it that way. Good catch. When you say Gen5 99% of people think of the 10'-15' Camaro.
Old 01-07-2018, 02:23 PM
Pray's Avatar
Thanks guys. I am starting to get my H/C combo's dialed in.
For some reason no matter what I commanded I couldn't get the trans to shift before the limiter on the 1/2 and it was revving to 7K on the 2/3. That and the converter not locking till the top of 3rd was killing me. I had the mph in 1st all the way down to 18mph and the rpm down to 6K. All it did was cause a much longer slip time and it still wouldn't shift. Had it shifted the 1/2 at 6,600, the 2/3 at 6,700 and locked the converter on the shift to 3rd this thing would have rocked.
Old 01-07-2018, 04:16 PM
Darth_V8r's Avatar
I recently rented a 2018 SS camaro A8. I was overall impressed but I felt like it could really benefit from a solid transmission tuning.
Old 01-08-2018, 04:25 AM
Pray's Avatar
The trans definitely needs a tune. It is night and day when you get it dialed in.
Old 01-08-2018, 12:55 PM
Pray,
Care to share any "ballpark" cam specs and/or overlap?
Or Flow #s for your Heads?
Old 01-08-2018, 01:30 PM
Pray's Avatar
Originally Posted by NAVYBLUE210
Pray,
​​​​​​​mid 220's/230's on a 111. 7* of overlap. Heads are 313cc and flow 380/270 @ .600"
Old 01-08-2018, 10:22 PM
Thanks for the data.
The date on the time slip says 1/1/2009 Is that correct?
Old 01-09-2018, 04:29 AM
Pray's Avatar
Yeah, I have about 300 slips with the same date on them. We even reset the computer at one track rental but the print out still read the same. It is what it is. Plus, we weren't racing at 6:51 a.m.
Old 01-11-2018, 12:12 AM
GrannySShifting's Avatar
Whats this weigh? Usually we see those et and traps out of upper 400 hp SAE dynojet numbers at 3800#s
Old 01-11-2018, 04:20 AM
Pray's Avatar
In what car, with what transmission with what converter?
The 6th Gens lose 3-4 mph once the converter goes in. I trapped 125 on the stock converter with bot ons. I dropped the 4C in and only trapped 121 a couple days later. And that was getting the converter to lock when it dropped into third. If you can't get the converter to lock till the top of 3rd or into 4th then you lose even more. We also have to remember that this car shifts 4 times in the 1/4 and with TM on it take about .4 sec per shift. Another big thing I have found is that you don't get the shift points correct for the 1/2 and the 2/3 you will drop ET and mph. If you over rev those gears the losses are substantial. I couldn't get this car to shift before the limiter in 1st and up near 7K on the 2/3. Both are well past what was needed. The other bid thing is that the converter wouldn't lock till the tip top of 3rd. It spent more time in 3rd trying to lock up then it did in 4th locked up.
I am not sure of the weight of this car but I would estimate that it is somewhere right around 3,800. My car is 3,840 and this one is the same model but has lighter rims and tires.
The dyno numbers I posted were in 6th. The car made 562rw in 5th. The car that I got the record from put down 545-560rw in 5th depending on the dyno. His car was under 3,600lbs and he trapped 104.4 in the 1/8 and 131 in the 1/4.
If you can show me some 6th Gens that are trapping higher or running quicker I would like to see them. I can post up my slips with DA and weight from my car once the converter went in if you like.
Old 01-11-2018, 10:32 AM
Im talking about unlocked 4L60es, Th400s, etc making 450-500rwhp at 3700-3800# going 10.30s-10.40s at 127-131 None had stellar 60 fts 1.31-1.42
Not 6th gens, Ive just seen alot of huge dyno numbers from them and they dont seem to run the numbers Id expect out of that. Every car loses mph when you put a converter in but gains ET big
Ive always seen if you need to lock the converter up to gain ET (who cares what the mph shows if its not accelerating faster) its too loose. Maybe go a little tighter on the converters because with so many gear splits the shift extension isnt falling way down like an undergeared 3 speed would and dont lock it at all. If all those shift events take so much time (thats 1.2 seconds your saying) seems super wasteful
Old 01-11-2018, 12:50 PM
Pray's Avatar
The conditions for sure weren't in my favor. Had the trans done what I wanted and we were not into a 10-15mph head wind I would have been in the 10.20's at 132+. This car was by no means totally lined out. and with a 1.45 60ft the time isn't all that bad.
The converters in the A8's make a nice 60ft but you only get a tenth or two out of them due to the loss of mph and all of the shifting. Not to mention if you leave TM in the car. With TM on you can see up to .6 from power off to power on. Plus this transmission lets one drum go before it puts the other drum on. So you have a pretty big time of converter slip between shifts. I was doing 1.57 60fts on the stock converter running 11.0's-11.1's. I dropped the converter in and went to 1.44-46 60ft's but only went high 10.8's to mid 10.9's. With how tight the gears are and how many shifts there are you have to get the converter locked in second. You are basically past peak hp from 1st-3rd with the converter unlocked. That is where your loss comes in.
Old 01-11-2018, 01:06 PM
7 Second Club
islander033's Avatar
Pray is A O K !
Old 01-12-2018, 04:26 AM
Pray's Avatar
Question for the group. The A8 starts with a 4.56 1st gear and a 1.27 5th gear. So the car is never in 1:1 going down the track. Do you guys think this could be hurting the over all mph and ET?
Old 01-12-2018, 05:11 AM
sxc Z28's Avatar
Yes, that's another reason rear gears would be a big help on these cars.
Quick Reply: Another Gen6 LTI H/C SBE build w/ track times. 588/528rw
