Fast 92 disassembly
the seal is not one piece.....and after removing the middle piece I realize I am not done porting by any means.....if I was getting paid by the hr to port......I could take a vacation
I need to find my epoxy too....thinking of deleting the center posts too
some of the ports are spot on....others are off by a hair....number 7 is really off
If you also end up needing to replace the gasket for the upper and lower shell, look for FAST Part # 54022. Its one long strip. You have to cut it to fit and I used some clear RTV silicone to connect and seal where the cuts were made. You should end up with a few inches of extra material when done, as they give you a little more than what is actually needed.
