Oil Pressure PID
Old 02-03-2018, 11:39 PM
andelee's Avatar
Unhappy Oil Pressure PID
Hi I'm Ande..I've just swapped a 2003 LS1 into my 59 El Camino.. I was wanted know if theres anyone out there that can tell me what software ect to use on either PC computer, Iphone or Android tablet to display an oil pressure gauge????
... I've been looking all over the net for days, with no answer..
PLS HELP!
Annde Lee
Old 02-04-2018, 12:24 AM
Restricted User
JoeNova's Avatar
The Oil pressure sensor doesn't go to the PCM, just the dash gauge.
Take the signal wire from the oil pressure sensor and feed it into the PCM on Pin 58 of the Red/Green connector.
Old 02-04-2018, 12:39 AM
andelee's Avatar
Really? Thanks heaps for yr help mate.
... couple of questions though. How should I display it? What is vest software? I don't mind paying.
Do I have to "add PID" to view a gauge?
thanks heaps mate!
Ande
Old 02-04-2018, 12:58 AM
andelee's Avatar
Also, which wire should I use, there's 3¿
Ande
Old 02-04-2018, 01:11 AM
andelee's Avatar
It looks that
• organ/black wire is 12v
• tan/white is from oil pressure sender (the wire in question?)
• tan/white to fuel pump¿
the wire in question (according to diagram) is the
tan/white on the middle of the plug. Does this sound correct?
thanks heaps mate!
Ande
Old 07-21-2019, 12:11 AM
Averrett's Avatar
Originally Posted by andelee
It looks that
thanks heaps mate!
Ande
Did you get this figured out? I'm trying to see oil pressure on my Torque app and if this works it will be great.
Old 07-21-2019, 09:21 AM
JoeRJr's Avatar
I'm not saying you're wrong here, but I've got conflicting info. If I look up a 2003 Vette it shows the Oil Pressure Signal on a 5V reference coming from Pin 7 on the PCM, and going to pin 58 already. Tan wire, white stripe. I'm not sure that helps much though. You still have to find a way to display it. I've got an Ultragauge for my LS Swap, but Oil Pressure is not one of the PIDs they display.
Joe
Old 07-21-2019, 03:37 PM
gofastwclass's Avatar
JoeRJr, you are correct. The C5 Corvette uses an oil pressure gauge that ties into the PCM. As far as I'm aware that is the only vehicle with a Gen III engine that uses the PCM to display oil pressure information.
To get this to work you need the C5 Corvette oil pressure sender, the appropriate plug, proper wiring and to enable the option within the PCM. I use HP Tuners to modify the PCM settings but other software may be able to make the changes.
Old 07-21-2019, 04:47 PM
Michael Yount's Avatar
True for the C6/E38 pcm as well - the oil pressure sender delivers its data to the computer.
Old 07-21-2019, 05:57 PM
ddnspider's Avatar
Most ditch EGR and use the EGR valve pintle position to monitor fuel, oil, or boost pressure. Very easy to do.
Old 07-21-2019, 06:29 PM
My motor doesn't have egr....
Old 07-21-2019, 06:59 PM
ddnspider's Avatar
That's the point....you have a free wire for where you aren't using the EGR...
Old 07-21-2019, 07:18 PM
ddnspider - trying to learn, so use a few more words in your responses, as if I were a 2nd grader.
If my pcm is already monitoring, or has potential to monitor, oil pressure from the sender, what do I need the free wire for? I don't understand....
Old 07-21-2019, 07:44 PM
ddnspider's Avatar
you don't need it,my comments were for the OP. If he doesn't have a way to monitor oil pressure then using the EGR pintle position is a way to do it.
Old 07-21-2019, 07:54 PM
For OP's benefit (and my learning) - can you elaborate a bit? If the PCM egr monitoring algorithm is expecting some sort of signal related to egr function on that wire, how will sending an oil pressure signal there accomplish monitoring of the oil pressure? Or are some other changes (via tuning) needed to do something different with that oil pressure signal?
Old 07-22-2019, 06:07 AM
ddnspider's Avatar
The EGR pintle position is a 0-5V analog input to the ECU. HPT and EFI Live allow you to create custom PID's based off of various inputs of the ECU. So you create a custom PID that takes the EGR pintle position input and uses the equation of a linear line based on min/max pressure vs. output voltage of the oil pressure sensor. This allows you to log oil pressure.
Old 07-22-2019, 06:30 AM
Thanks spider for taking the time. For most of us, this is not "Very easy to do." In fact, I went out of my way to put together a combo that worked well without me having to ever get into the pcm/ecu for any "tuning" - obviously because I didn't have a clue how any of that worked. So when you take the time to actually lay it out, we can follow along and gain an understanding of what's possible.
Now - what in the heck is a PID? LOL....
Old 07-22-2019, 06:53 AM
ddnspider's Avatar
PID is just a fancy way to say you're logging a parameter with the tuning software.....like coolant temp, intake temp, etc. Technically it usually involves a modification of a sensor input, but keeping it basic.....you're just logging stuff. So you log the oil pressure sensor, but all you see is a varying voltage.....not very useful. But if you know how the sensor works, you can turn the analog voltage into an actual pressure that the engine is seeing....much more useful.
Old 07-22-2019, 06:56 AM
Proportional-integral-derivative perhaps? Now you've got me investigating stuff. No good can come from this....
Cheese Weasel (07-22-2019)
Old 07-22-2019, 07:18 AM
ddnspider's Avatar
Yes, but why I didn't type that....no point in confusing people. K.I.S.S.
Quick Reply: Oil Pressure PID
