Roller rockers, pedestal mount: which are the most reliable?
I might get to push my plans up, and get the heads done in April. So, I need to know which pedestal/std mount roller rockers are the most reliable. All of the threads that I have looked at are over 5 years old, so I am looking for some current info....
- Heads will be Frankenstein Stage 1 243.
- Cam lift is around .590/.610
- Don't want/need stud/shaft mount rockers.
- Don't want/need adjustable.
- Must be 1.7 ratio
So... Scorpion, Harland Sharp, Yella Terra?
- Must be 1.7 ratio
I should have asked first, what type of metal are the valve guides in those Frankenstein heads? Bronze will need roller tips, the powered steel should handle the stock rockers just fine. Somebody please correct me if I'm wrong.
As for the choice YTs always seemed to be the most popular, was always told HS are nose heavy but Trick Flow use to recommend them for their bronze guides.
I have a car I bought with a complete LME 408, has TFS as cast 220s with bronze guides & they built it with YT ultralights but it has a pretty big cam.
I'd do CHE bushings on a smaller cam.
CHE bushing
Received 1,835 Likes
I ran YT for about three years DD. No failure
Induction Hardened STEEL Guides
Hi TA, I would have my Steel Guides installed in your new heads (take-offs) AND use my 8mm/10mm Step Studs.
The heads will need to be tapped to 10mm, this is also Jake "tech" (10mm holes) for rocker arms.
I would use OEM S/S rockers with CHE's.
Lance
Lance
I don't want to reuse my stock rockers, since they are almost 20 years old. Scorpion and Harland Sharp are less expensive that new stock rockers with the trunion upgrade.
It doesn't make sense to me to get stock rockers when I can have rollers for around the same price.
I just calculated it. It increases lift 1%. NOT worth even thinking about! You're dissing them because of THAT?
Will they be the right length after you put new rockers in, no matter who's you use?
