Adjustable Rear LCAs Necessary?
I know this question has likely been asked a bunch of times, but here I go anyways: is it worth it to buy adjustable rear lower control arms, or will fixed length be fine?
The usual answer that I saw in my search was "you usually don't need adjustable unless you're lowered quite a bit, but you might as well just in case". This is a fine answer and it makes sense, but I guess I'm hoping for some people with similar setups/mods to chime in with their experiences.
My setup is the following, 97 Trans Am WS6:
- Strano springs and Koni STR.T shocks
- stock rear end with 4.10 gears
- some type of non-adjustable upgraded torque arm (was on the car when I bought it)
- Spohn weld-in LCA relocation brackets (not yet installed)
Overall the car isn't lowered a lot, and the rear end isn't heavily modded. Anyone out there with a similar setup run into any issues with non-adjustable RLCA's?
Thanks, should have added to my list that I have an adjustable PHB. Mine is also a street car.
I know adjustment is nice to have if you need it, but at the same time I don't want to spend twice as much on something to never use the adjustment.
I'm lowered and wish that mine WEREN'T adjustable. However there was a certain type that I wanted and that was the only way they came. I put them on when I did my lowering springs and shocks. I did my best to get the new ones the same length as the old factory ones, what a **** show. I had to get them close and then adjust them on the car, measuring, adjusting, measuring, adjusting, measuring, adjusting.... and I still am not confident that they are all that close.
I'd run from adjustables unless there is a true need.
I'm with you guys, my non adjustable $100 umi poly lca's have served one hell of a great purpose....with the new tires and rear end and the direction this car has come it was time to go with adjustable lca's so I'm unfortunately saying good bye to my simple bolt in boys and I'll be adjusting and measuring my *** off all season im sure.
Thanks guys, that's good feedback I hadn't thought of. More adjustable parts just means another way for variation or movement to creep into the equation.
Yes I am going to install the brackets at the same time. The Spohn ones I got have one collared bolt that goes to the stock RLCA mounting location, and then it welds on to stop it from rotating (maybe this is how all the weld-on ones are). I was thinking I could bolt and clamp them in place and then measure, and if things were off I could shim the relocation bracket before welding it. Not sure if that makes sense or not.
Not really following. I went with these bad boys...
https://www.foundersperformance.com/...tion-brackets/
...and think they are great. Really nice quality. Also have their LCA's.
https://www.foundersperformance.com/...r-control-arm/
Check these. What I like about them is that they have a unique bushing design that privodes zero deflection forwards and backwards but they can still deflect side ti side when turning. Best of both worlds while being 100% streetable. Love them. I got the adjustable ones and they eliminated my wheel hop.
Thanks for the suggestions, guys. I was looking at those Founders arms, but ended up going with UMI. Unfortunately, being in Canada the shipping costs vary by a lot, and Founders wanted just as much for shipping as the price of the arms. UMI through eBay had the best total price for arms, shipping, and duties, and they have a good reputation around here, and they'll match the UMI PHB I already have.
Just a suggestion
