Rocker Arm Install
Rocker Arm Install
Putting my engine back together and I noticed as i tighten up my rocker arms the springs, even the ones where the valves should be closed are moving down ever so slightly.
Measured 11.25 turns with the pushrod checker, which says my rods should be 7.423 and i have 7.425 pushrods...
Is this normal?
Is this normal?
Is this normal?
Is this normal?
Assuming the pushrod length is OK, yes this is normal. The lifter will bleed down a bit and the valve should close. If it doesn't, than the pushrod length is suspect. If your setup is using the stock rockers, you should be following the GM procedure to prevent driving the valve into the piston and to obtain the proper bolt preload.
Good point on the GM procedure for piston/valve clearance, although i don't really have an issue with that because I have a TON of valve clearance because of my setup.
This is completely what happend... Caught me off guard at first because I don't remember ever seeing anyone say anything about that but when you think about it makes total sense.
