Question about injectors
Well, i bought an LS6 intake, it came with LS6 injectors. But, they need to be cleaned up really bad. Certain rubber seals are broken and messed up. So, i'm looking at sending them to witchhunter injector cleaning.
I have self ported 862 heads, TSP 228r cam, LS6 intake.
Not sure if I should get the LS6 injectors cleaned, or if I need to buy bigger injectors. If i'm going to spend almost $200 on cleaning, maybe I use that towards some SVO 30#?
Thanks!
Thanks!
Restricted User
If you're going to go through the hassle of upgrading injectors, at least UPGRADE them. A 30 lb injector is BARELY an upgrade and you'll have to go through the hassle of finding a connector/injector data for the tune.
You can probably get some factory GM flex fuel injectors that'll drop right in your LS6, use the factory connectors, and flow more.
Make sure that there is data for your injectors before buying them. Even some standard GM/Bosch injectors can be difficult to find the correct data for. That's what I've learned about buying injectors from personal experience and see people with a brand new set of whatevers trying to hunt down the data after the fact. Don't assume it will come with the injectors.
Call the company and have them send you the data upfront. It's free. A set of whatever injectors isn't much good without data. I can't count how many posts I've seen with guys asking for data even with "stock" GM injectors. It seems like the data for some of the stuff out there is a secret or something. It's getting better, but it's worth making a few phone calls before buying anything.
Injector connection is pretty good about providing data for what they sell. I've seen other companies with "data" that is very limited or requires extensive conversions just to use it. IC has it all in an easy to use excel document that they will email to you for free.
Lmao... WHAT? And I guess Greg Banish is a hack right? You're an idiot.
Buttsore? Hardly. I just prefer to do things the correct way. I don't assume to be smarter than the engineers that designed the tables. Is it possible? Sure. Doesn't mean it's right.
100+ cars? You want a medal or something? I don't really care how many cars you used incorrect data on.
I guess I'll go back to being another idiot that doesn't have his own flow bench and degree in advanced mechanical engineering. I know I'm such a hack for looking for proper data, to make things "easier", because I suck at tuning and all. Lol. Yeah, okay.
Also what do you mean advanced mechanical... I've never heard of such a thing. there is an undergrad mech degree, right? A masters maybe? and a PhD doctoral. Is it some kind of non-accredited university course you are talking about? Or were you just trying to sound 'advanced' by throwing the word 'advanced' in front of a regular degree?
You missed "flow rate" and at what "manifold pressures" too there bud. You do what you do with your trial and error and risk scrapping 25k engines all you want. I agree it can be done without data, but why when there IS data available for A LOT of injectors at all different flows?
Time open on a larger injector into various manifold pressures will vary greatly between different injector sizes. 3ms on a 60# injector doesn't equal 3ms on a 30#, and because flow INCREASES with more pressure in the manifold, how do you "figure that out" through trial and error without testing it?
Sorry, but a scanner simply isn't enough to find these values from one injector to the next. People like Greg Banish spent years finding this data. Why would he bother if your method is so superior? If it is why don't you sell a DVD or have a book out yet? Why does GM even bother with it? Riddle me that smart guy.
This is why you have no friends on this forum. You just have to always disagree with solid advice. Maybe the OP doesn't have such a tuner as "advanced" as you are in his area. And by that I mean jacked up for not using reliable data.
Sorry for mucking up your thread OP. Don't listen to this dude. Get some injectors with good data so you don't run into problems later. It's worth the extra 10 whole minutes to find some that are tested and come with reliable data.
At that time he barely knew anything about LS engines, as he was "scoping out" the details. He is a self-styled intellectual who feels he knows more than the rest of us on ANYTHING. He picks up a thread of info on something, a week later he's an authority on it. Slight exaggeration, but you get it.
"The injectors are cleaned by an ultrasonic cleaning machine. After cleaning, new filter baskets, o-rings, spacers and pintle caps are installed. We include a service report that shows the before and after flow of your injectors."
https://www.ebay.com/itm/Fuel-Inject...NTeX8p&vxp=mtr
fyi, a member on the wbody forum gave me this business to send injectors to clean and flow-match:
click here
I haven't any experience with this business yet but I'm planning on sending them my l67 injectors to clean and flow match.
click here
Denso Injectors + Flow Increase
Hi RX7, the cost to "clean/flow" a fuel injector is about 1/2 that of the new Denso Fuel Injector I sell.
The Denso injector has a smaller fuel droplet size, good for Idle Quality/reduced Fuel Consumption.
The set of eight I supply IS FLOW MATCHED.
The set of eight I supply will be correct for your HP request.
Your engine should require a 36-42 .lbs fuel injector.
I fit a 42 Denso as common for your needs ?
This size in Denso will Idle better than OEM.
Lance
Lance
