Yo my EE homies I need a lil help
I'm using this old *** lnc-001 2step and it is randomly dropping cylinder 8 when not activated.
I have read the early lingenfelter stuff wasn't shielded very well and wondering if that's my issue.
I had planned to grab some ferrite chokes and see if that helped cut the noise, but I'm not sure if the voltage drop they will induce would create other problems.
Penny for your thoughts
You think that's bad....my LNC would literally shut the car off during a WOT pull.....when it wasnt activated. They replaced it and all was well. Make sure your harnesses off the LNC to the coil pack harnesses are ran perpendicular to other wiring as much as possible to prevent coupling.
Edit....I also noticed an improvement using stock plug wires over aftermarket when the LNC was hooked up.
Double edit....cable ferrites won't drop any voltage if you get 1 that has the right frequency range. They are not all created equal and they have graphs of impedance vs. frequency.
Sheeeit, I had no idea they came in different flavors. I was just gonna grab some random beads from eBay.
i wouldn't have the slightest clue where to begin, no o-scope or really any knowledge to use it.
Obviously this ten year old version is not gonna cut it. Which one did you end up with?
I had the LNC-002 I believe that is no longer made.
