Accessory drive critique
Old 05-20-2018, 05:32 PM
Lathedog's Avatar
Default Accessory drive critique
hi all. I am putting a 5.3 in a s10 frame under a 51 chevy truck I had to move the ac compressor to the top since it wouldn’t fit in between frame rails.
Wanted it tight and compact so went with old design R4 pump. They are short so it fits well.
Feel free to critique. Hate to miss something. Thanks. Jim
Here they are
Old 05-20-2018, 09:35 PM
Karlw's Avatar
You need more wrap around the power steering pulley. That thing will screech like mad as it is right now.
Old 05-20-2018, 09:39 PM
Lathedog's Avatar
Can put a larger pulley on tensioner. I have the belt shortened where it’s sitting can let off on tensioner more. This is what I need to hear. Thanks
Old 05-21-2018, 06:48 AM
Michael Yount's Avatar
More wrap on PS was my first impression as well. Can you relocate the pulley above the PS pulley towards the water pump?
Old 05-21-2018, 07:32 AM
Lathedog's Avatar
I can move it a little . Will take a look at it. Thanks
Old 05-21-2018, 09:17 AM
ls1nova71's Avatar
Another issue you are going to run into is you will have to pull the upper radiator hose to put the belt on. Not the end of the world, but certainly an inconvenience.
Old 05-21-2018, 09:27 AM
Lathedog's Avatar
Honestly that isn’t a problem but good catch
Old 05-21-2018, 10:27 AM
Technically - hose has to come off to replace the belt....but the belt can come off the pulleys for other work/maintenance. Hang it on the hose.
Old 05-21-2018, 10:30 AM
Received 3,017 Likes on 2,348 Posts
This was starting to look like one of those chicken-or-egg debates..... lol
Old 05-21-2018, 02:27 PM
jmd
jmd's Avatar
Originally Posted by Lathedog
Here they are
I would add a brace at the back of the comp. and try to pull this off ^
Old 05-21-2018, 10:27 PM
ls1nova71's Avatar
That looks like a good idea, but you would be giving up about 1/3 of the crank belt wrap which could cause other issues. I think if the radiator hose isn't an issue, ii would try to move the belt tensioner in a bit, like in the last pic, and go with that.
Old 05-22-2018, 05:39 AM
Lathedog's Avatar
I agree nova.. don’t think I want to lose the drive surface. I’ll move the tensioner in today
Old 05-22-2018, 12:22 PM
jmd
jmd's Avatar
Keeping things simple, the crank and PS wrap can be increased with a pulley added above the gap between the two. The tensioner could remain outboard of the belt. And the hose would still be free.
Or the tensioner could be re-located and rotated to do the same, and the idler added inboard of the right hand vertical belt length.
As reliable as serp belts are, there's still no reason on this project to capture the coolant hose.
Old 05-22-2018, 03:03 PM
Lathedog's Avatar
Like this
Old 05-22-2018, 03:08 PM
Lathedog's Avatar
Better yet.. eliminate the idler at alternator. That cleans it up
Old 05-22-2018, 03:10 PM
Lathedog's Avatar
Thanks guys. Just redo holes for tensioner and that will work. 👍🏻
Old 05-22-2018, 03:11 PM
Lathedog's Avatar
If your bored I have another issue to overcome 😬
Old 05-22-2018, 04:11 PM
Lathedog's Avatar
There. Moved tensioner in an inch. Bigger pulley.
Old 05-22-2018, 04:14 PM
Lathedog's Avatar
There
Old 05-22-2018, 06:04 PM
garys 68's Avatar
Simple way to add a little more wrap. Add an idler and spacer in the lower accessory bolt hole.
See post 78 here.
https://ls1tech.com/forums/conversio...2-build-4.html
