Bad dyno tuner?
Old 06-05-2018, 05:18 PM
Road_House's Avatar
Default Bad dyno tuner?
Just got back from the dyno and am completely disappointed. Did the tuner mess up or is this all I am going to get? A4 car
parts list:
fast 92 w/ speed density and slp lid
fast fuel rails
42lb injectors
2.5 5.3 prc Texas speed heads
ms3 cam 238/242
1 3/4 headers straight piped
it does have a loose converter
dyno shows 347hp & 340 torque
Old 06-05-2018, 05:39 PM
HCI2000SS's Avatar
A6? What kind of car is this?
Old 06-05-2018, 05:45 PM
Road_House's Avatar
a4, my bad. Just a bit frazzled right now
Old 06-05-2018, 06:07 PM
HCI2000SS's Avatar
I was thinking you meant that, but thought id ask to be sure lol. Yeah thats odd. How does it run, idle, etc?
Old 06-05-2018, 06:14 PM
NOWHERE does it say engine size. 4.8? 5.3? 5.7? 6.0? It can be any of these
ddnspider's Avatar
About 75whp down....locked or unlocked on the Dyno? You have any info like AFR or timing?
Old 06-05-2018, 06:19 PM
SRT8.Acelleration's Avatar
something is seriously wrong, parts? combo? tuning? not sure, but that is just barley above stock HP/TQ..
Cam is a little too big imho - you dont need that much duration on a stock compression ls1, lose too much dynamic compression..
Also i'd run 1 7/8 headers and tru-duals
I'd run a smaller cam and find a different tuner.
i made 400/400 on a stock short block ls1 with LS6 heads and Ls6 intake with a 224 cam.
Old 06-05-2018, 06:36 PM
ddnspider's Avatar
Theyre 5.3 heads....not stock compression.
Old 06-05-2018, 06:38 PM
Road_House's Avatar
runs ok, when idling it gets down to about 600rpm. When I gassed on it, it redlined to 6500rpm and stuck there for a second or two, doesn't seem to shift when it should be under wot
Old 06-05-2018, 06:39 PM
Road_House's Avatar
5.7 ls1...
Old 06-05-2018, 06:41 PM
Road_House's Avatar
I am not sure about the locked or unlocked, wideband is 14.14
Old 06-05-2018, 06:44 PM
Road_House's Avatar
has 10.8/1 -11/1 compression, forget which. Also the 1 3/4 are true duals
Old 06-05-2018, 07:12 PM
ddnspider's Avatar
You mean the wideband says 14.14 at idle right? Not at WOT,right? Should be somewhere in the middle to high 12s during WOT.
Old 06-05-2018, 07:22 PM
Road_House's Avatar
yes
Old 06-05-2018, 08:03 PM
98CayenneT/A's Avatar
What converter and what y pipe?
The merger and 2.5 in. outlet on the y pipe needs to go bye bye for sure
Old 06-05-2018, 08:11 PM
Road_House's Avatar
ptc with a 3800 stall. No y pipe, true duals.
thanks for the responses guys
Old 06-05-2018, 08:43 PM
Floorman279's Avatar
who starts a dyno pull at 4000?
Old 06-05-2018, 08:45 PM
if the car feels faster than 350 hp i would try a different dyno
Old 06-06-2018, 01:05 AM
Super Hulk Smash
JakeFusion's Avatar
Unlocked stalled cars dyno like crap.
If you can't lock it without destroying the converter on the dyno, run it on the track and see what it does.
Old 06-06-2018, 01:11 AM
Well, this could all be BS, if the dyno was not set up properly then your readings will be wrong, either high or low. This could be just a miscalibrated dyno.... garbage in, garbage out...
find another shop and try again, there is noway that vehicle made that low HP/TQ unless something is really wrong..
