flexfuel sensor question...
Seems like the price is super inflated. Sensor, harness, and fittings can be bought separately for well under $150. Not sure why you'd bother with the tuninglab since you still have to wire the sensor to the ECU yourself anyway.
Kind of what I was thinking. I've got maybe $60 total in hooking up my flex sensor.
how are your guys connecting these with aftermarket fuel systems? I'm interested to run a FF setup, but I run a -8an feed. Not sure what the diameter is on the connections for the sensor.
I don't have a sensor to check, how does the e85 sensor's inlet/outlet diameter compare to PTFE -8an I.D.? I got it, they do make a -8an quick connect to mate to the sensor but I'd hate to create a restriction in the system even if -8an return isn't "necessary" (for me, at this time) because I may eventually go to -10an feed and retain the -8 return.
This is exactly what I was thinking of doing and likely the route I will go. thanks!
