need Help! i am trying to figure out fueling
First here is my set up
Setup as follows:
6.0 forged bottom end , dish pistons 7:1 comp
6.2 stock truck heads
78/75 turbo
80lb deka injectors
twin 340l intank fuel pumps
2010 zr1 cam 211/230 @ .050 valve lift and .558/.552 lift
LS2 cam sensor in timing cover
Ict billet intake w/102 mm Tb
napa crb219481 3 bar map sensor ( gm 12223861 alt replacement)
wastegate w/14lb spring
Ok no my issue is that I cant figure out why I have to crank up the Main VE table so high to get it to run? I know that my injector data I not set to spec because if i do then it wont run at all the injector data I have right now I got from the manufacture , as far as flow,mpw,dpw, offset and spa. Is there a setting that I am missing that i need to turn off or adjust?
attached is current tune and log.
Setup as follows:
78/75 turbo
80lb deka injectors
I tried it out ,with the injector setting you sent and my org Ve and all it does is start and then dies , it does not stay running
92 pump, the only way it runs is if i turn up the VE it runs less on the injector duty % with your info but it still has what seems like a misfire stutter , at random rpm until I get above 3000 rpm and the then it clears up until I am nder boost and it starts to lean out at about 4500 rpm. the funny thing is I never see the stutter on the scan
here is my log and tune with afr err correction done on my last drive w/ smoothing hit twice
2 5/8” autometer
i need to figure out why the ecm is adding so much, but at the same time the wideband is not showing the added fuel
I am assuming thats an electric gauge, we always use a mechanical gauge just to help rule out any variables. When in closed loop your wideband isnt going show the fuel being added, its going to be showing 14.6 at idle and cruise since thats what the fuel trims are correcting your fuel to. If you put it in open loop then the wideband will show you the correct air fuel ratio.
You have something going on mechanically or with your fuel system or different injectors than you think. The numbers in your VE are an instant red flag thats somethings way off.
Sorry I typo'd about the gauge, it a 100psi mechanical plumbed into the regulator port, how do i keep it from going into closed loop?
Why would the wideband not read in closed loop?
When in closed loop your o2 sensors are always going to be correcting your fuel using fuel trims so when the fuel trims are adding 30% fuel your will wideband will still read 14.6 instead of 20, what it would be if you were in OL. Here is the last tune you posted in OL.
Open loop youll see the actual AFR that is flowing past the wb sensor. Closed loop your WB will show 14.7ish because in closed loop the pcm uses the narrowband o2's to trim the fuel to stoic. Which is 14.7
If you are running over 100% dc on your injectors, nothing but bigger injectors will really cure that. They can only flow so much.
