Lsa Blower Noise, Am I Screwed?
So I just got to start up my lsa swapped 5.3 tonight. The motor is still untuned, just working the kinks out, but at idle there is a LOUD whine in which I'm assuming is bearing noise. I bought the blower on eBay at the end of last year. I paid 2500 plus shipping, it came with a new lid, hardware, lsa rail, and all the gaskets. It was listed as a low mile unit, but it did need the isolator replaced which is the norm. Here are a few videos of the sound, when I first started it up, then the bearing noise from the snout and possibly the blower after I pulled it apart shortly after.
I'm totally fine with ordering a kit and replacing the snout bearings, as I have access to a shop press, but what I'm more concerned about is the noise from the rotors. Is that bearing noise I'm hearing, or just the sound the rotors make? I don't want to replace snout bearings if the whole blower needs a rebuild. Also, when I had it apart replacing the isolator, the rotors looked fine. No gouges or any contact with the rear case that I could see. Any insight would be greatly appreciated, thanks in advance
Running:
Snout and bearing noise:
Running:
https://www.ctsvowners.com/forum/62-...ics/876?page=1
Alright so I got the snout back on and moved the intake a bit, and yea the noise moved with the filter. Here it is running fully warmed up. The noise goes away when the pcv vacuum hose is removed. I’m assuming the air from the vacuum leak is diverting some air from the iac and causing less noise? Either way, it’s not the bearings like everyone said. 👍👍👍
