Nitrous Outlet single wet nozzle to plate kit, gains hp or no?
My poor Nitrous Outlet nitrous kit has been through the ringer...
First, was a DRY nozzle kit, to help (or should I say, TRY to help) spool my old rear mount turbo...
Sold the whole turbo setup and converted to a WET nozzle kit....
Couple days ago, Ebay had a 15% off everything sale, so I ordered a Wet Nozzle to 92mm Plate conversion setup....
Mainly, I do not care for having the nozzle "mounted" into the silicone bellows (speed density car)
But am wondering if the PLATE(with it's better distribution), should, jet for jet, make about the same, or more HP?
On a side note:
With a 200hp n2o jet, I run a 150hp fuel jet, and still see AFR no leaner than 10.8:1. I am hoping for better adjustability with the plate as well.
On a side note:
anyway....
Nothing different but the Nitrous Outlet 92mm plate replacing the Nitrous Outlet wet nozzle...same jetting, as recommended by manufacturer's jet chart...
2/10th's and just shy of 2 MPH slower...car runs near identical incrementals footbraking or using transbrake, but I always mix it up and use both everytime
It was a half point RICHER though, according to datalogs...
HPTuners logs usually are 10.8:1 at WOT (which I think is already too rich)
Last night, I saw as low as 10.3:1...but unfortunately forgot my jet box... (78 nitrous/35 fuel, 200hp, is what I had in there)
I "HOPE" it was just a weather related decrease, and not a decrease strictly due to the plate versus the nozzle...
I don't know where to locate a weather summary from 3 weeks ago, to compare to yesterday's...in fact, can't even find one for yesterday, LOL
I think next time, I will have the nozzle back in the mix, and make 2 passes with it, then 2 passes with the plate, same day, same weather, same jets, and get a better comparison.
I am using the, as-delivered, -4 from bottle to solenoid, and -3 from both solenoids to jets (plate or nozzle)
Nitrous Outlet Race Hose
You've got a restriction with that 3an line. A 3an line will tap out around 175 hp. You need what's called a "race" hose. It is a 4an line with a 3an b-nut on one end. Check out the link below. You will also need an 1/8NPT X 4an fitting for your nitrous solenoid outlet.
I started with an X series DRY nozzle kit.
Then converted it to a WET nozzle kit.
Then finally, converted it to a 92mm WET PLATE...so probably already over spent by $100 (give or take) as opposed to buying the NON-X series wet plate (and it's included "race" hose and bigger solenoids) from the beginning...(which is 100% my fault)
I now see that the X series nitrous solenoid only has a .078" orifice, so to up the shot to what I wanted to, I'd need the bigger solenoid and the race hose....dammit
I guess I'll either just settle with a 150 shot, or try to sell what I have, minus the bottle, and spend $700 on the better wet plate kit...
....sheesh...LOL...j/k
I wanted to try a 250 shot. I think that (and my needed fuel tuning) would get me those last 2/10's to run easy 10's...heck, the 200 shot would probably have done it with a more realistic AFR. (It went 11.20's at 121-122, 4 in a row, with a mid 10:1 AFR...with 78N/31F jets)
Planning to use the new solenoids, hardlines for Test & Tunes, and if what I have now can't fetch me $300 or so, I'll re-install the wet nozzle with 100hp jetting for bracket racing....using the plate strictly for N/T fun.
Well, I actually had a couple jets, and the "race" hose in my cart, waiting until I had a chance to complete the order, and instead found a mostly complete Nitrous Outlet 90mm plate kit, with the much bigger solenoids, and the hard lines. The kit specs say it is capable of 400hp with additional jets, so I'd assume (hopefully, correctly) that a 200 or even a 250 shot, will easily FLOW through the included hard lines, since the advertising for the kit says it is capable with nothing more than jets??
Sorry. I should have clarified...
I only bought the kit incomplete...no lines, no bottle
it does already have a -6AN fitting into the N2O solenoid, but will I "need" the bigger line to feed a 200-250 shot (max), or will my existing -4AN line support 250? I'd much rather buy a new solenoid fitting, than new.line and bottle nut, and also have to reconfigure my existing -4AN purge setup...but will if its recommended.
My end goal is to use the plate and newly acquired big solenoids for T&T and N/T fun runs, and use my existing X series solenoids and the wet nozzle (if needed) for bracket racing...but 100% NOT as a dual stage setup.
Just to update....
-6 line and higher flow capable solenoids DEFINITELY make this same 200hp shot hit harder.
1st pass last night, spun bad (which it never has done before), with nearly a 1 second recovery, still went 11.43@123, but was a bit lean at 12.8:1 AFR (78N/28F) through the traps.
Swapped in 35 fuel jet, as I had nothing between the 28 and 35, and it brought the AFR a lot closer, but a little rich now...
2nd pass, hooked great, pulled the front wheels and a 1.50 sixty foot, but for some reason, was seeing a constant 8 degree retard (last time this happened, a few months ago, the Knock Sensors were replaced and it was fine).
The 8 degrees KR, combined with the LNC-2000 retarding timing another 10-11, well showed an actual TOTAL TIMING figure of -1 to -2 degrees which turned my nice launch into a turd run...11.65@114
Not sure what's going on with the KR. I do not believe it is seeing TRUE KNOCK, as timing is very conservative (16 degrees @ WOT, OFF NITROUS), fuel delivery and octane are good, and nitrous AFR was mid 11's most of the run...Going to start a new thread in the TUNING subforum
