F-body garage clean out stock and performance
Price
$1,234
- Location Owasso, OK, 74055, USA
I'm combining a couple of my listings here and will be gradually adding parts as I clean up my garage. All parts came off my 01SS because I am building a boosted motor and were in good working condition when removed.
All prices are shipped to the lower 48 states.
water pump- notched for Fast 102- $70 shipped SOLD!
radiator- $65 shipped SOLD!
cooling fans- $65 shipped SOLD!
Ls1/ls6 valve covers, one is silver and the other has the painted stripped- $50 shipped SOLD!
Powerbond under drive pulley and belt- $120 shipped SOLD!
UMI tunnel brace for UMI torque arm, has a few chips in paint, part# 2202AS-$115 shipped SOLD!
ABS block with TCS- $75 shipped SOLD!
ABS block bracket- $15 shipped SOLD!
Brake lines to master cylinder- $20 shipped
LS1/LS6 lifters- $30 shipped
Lifter trays- $15 shipped
Alternator bracket- $50 shipped SOLD!
Evap purge valve- $25 shipped SOLD!
3ft Stainless Steel fuel line with -6AN Fittings (used for my fuel line to fuel rails)- $30 shipped
LS1 coolant crossover and steam blocks- $50 shipped SOLD!
Timing Cover (painted black)- 30 shipped
Coil pack brackets- $30 shipped
Aluminum driveshaft- $150 shipped
Oil dipstick and tube- $45 shipped
Bosch O2 sensors- $30 shipped- were in perfectly good working condition when removed. Had about 3k on them. Part# 0258005738
Kicker 6.5" speakers- came out of my truck. Worked just fine when removed. $30 shipped SOLD!
Custom grind cam from TSP-$280
It was custom spec'd for my 408 with PRC stage 2.5 LS6 heads and FAST 102 manifold/ TB, and was intended to be a max effort cam. Specs are 247/255 .623/.623 113 SOLD!
I'm combining a couple of my listings here and will be gradually adding parts as I clean up my garage. All parts came off my 01SS because I am building a boosted motor and were in good working condition when removed. Pm or text is fastest way to get a hold of me. 918-284-4025
all prices are shipped to the lower 48 states.
ABS block for 4 channel car- $90 shipped
I ran this came for about 3,100 miles. It was custom spec'd for my 408 and was intended to be a max effort cam. I will dig up the specs card tonight after work.
