My 3180# LQ4 Powered Car
Old 09-18-2018, 10:04 AM
LS-Vega's Avatar
Default My 3180# LQ4 Powered Car
I'm running a stock head, rod, piston, and crank LQ4 with a Holley Low rise intake, 996 CFM ProSystems carb, 1 3/4" headers, PowerGlide, 5500 stall, 4.30:1 gear, 28" tall slicks The cam is the Texas Speed MS4. I am trying very hard to make a 10 second pass before the end of the season. These time slips were from a 92 degree day with near 70% humidity. Run at 27 degrees timing and 93 octane fuel.
car #3200
car #3200 time trials
Old 09-18-2018, 11:54 PM
Rick01SS's Avatar
Just need some better air. Using Density Altitude (DA) is best for judging weather. www.airdensityonline.com and find your local track.
Old 09-19-2018, 06:36 PM
Doug G's Avatar
Why so low on the timing ?
Have you tried any other settings ?
Shift points ?
Launch RPM ?
Footbrake or trans brake ?
Looks real consistent though.
Old 09-20-2018, 07:41 AM
LS-Vega's Avatar
Have you tried any other settings ? what would you suggest for timing? I tried mid 30's before, slowed down a bit.
Shift points ? I shift at 6700 and go through the traps at 6500 (1/4 mile)
Launch RPM ? 5200
Footbrake or trans brake ? Transbrake
I'll try a different timing curve this weekend, and extend the shift point a little, It's supposed to be cooler as well so I may jet the carb up too.
Old 09-22-2018, 09:52 AM
Doug G's Avatar
I started at 32 and went up from there until she dropped off, never tried less than 32
I'm running a Mighty Demon jetted to 78/90
I launch off the foot brake at 1000-1200 with a 5000 stall/TH350 combo
Shifting at 7000-7200 and cross at 7000
I know you have 10's in that thing....
