Newby ls question?
Newby ls question?
I recently bought a 99 ss wrecked for the engine to swap it into my 1970 camaro restomod project. The engine is an lq9 bottom end (60000 mile) with ported 241 heads ls6 intake & throttlebody texas speed .600 lift cam (supposedly). The guy I bought it from said he had driven the car about 2k miles since doing the engine. He lost the cam card so I am going to pull the timing cover and cam and get the grind numbers. While I've got it tore down for that is there anything else I should check or replace while I'm in there? This is the first ls motor I've owned and am not sure on what to look for if anything. Engine ran well (could drive it much with wreck damage) with no valvetrain noise and good oil pressure. No overheating or oil leaks either.
It was a running engine? Hell, just throw the thing in there and run it, see what it does.... i wouldn't tear anything apart unless its a dog, if it runs good and your happy with it just run it.
^^^^^^^This^^^^^^^^ Sounds like you got a good engine! RUN that puppy!
