Fitech 92mm 4bolt throttle body question
This is kind of a strange question I realize but I am installing a TBSS intake on my turbo lq4, the hood on my car slopes down quite a bit and I am running into some fitment issues with the china throttle body and the stock gen 3 truck tb on a adapter. I saw the new 92mm fitech 92mm tb part number 70061, I was wondering if anyone here has on off the car and can measure in the center of the throttle body, from the bottom of the flange to the highest point on the tb casting IE where the iac goes in. it looks to be the lowest profile 4 bolt throttle body out there, I have a dbw tb that im gonna hack up to check fitment. thanks
When it comes to hood/TB conflicts, TB wins. Hack the hood, not the TB
In which case you might have to switch to a Dorman LS2 to work as well as the TBSS, in case the TB doesn't clear the hood. Which car are you working with?
Unless I'm mistaken Holley makes an angle adapter that works either way (unless they have 2 different ones). It might work for you. Check it out!
