TR-3650 for LS, options/?s.
Old 10-19-2018, 08:53 AM
Stampede4ever's Avatar
Default TR-3650 for LS, options/?s.
I picked up a TR-3650 out of an 03 Mustang, and have/had the intentions of making adapter for the LS, using the T56 bellhousing. But I'm at the point of selling it buying a used TKO, money wise might be cheaper using the 3650, if and when a replacement is needed.
What do you guys think?
Thanks.
Old 10-19-2018, 09:20 AM
Restricted User
JoeNova's Avatar
Money wise it might be cheaper to use a transmission that already works...
Old 10-19-2018, 12:31 PM
ryeguy2006a's Avatar
I saw a thread on here a while ago where a guy was doing an LS swap and used a 3650 in the Fox Mustang. The biggest drawback was that the bellhousing was somewhere in the ballpark of $700 bucks.
Old 10-19-2018, 07:01 PM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
Look up G-Force. They make an adapter for the 3650 to mount to older SBC bells.
Andrew
Old 10-20-2018, 12:06 PM
Yes, that was/is my intention, the adapter is $450.00, plus you will need to get the 05 and up 3650 input shaft. Just a note, AMP is making 26 splined input shafts, and they are $300.00. I'm going to try and sell the 3650, get my money out of it and buy a TKO 500 I have a lead on. But, either way it's about the same $ wise.
Thanks.
Old 10-20-2018, 12:37 PM
I don't know this for a fact, but I think the 3650 is a better shifting transmission than the TKO. The TKO uses older T10 style synchro gears and they are inadequate for dealing with the mass of all the gears. I'm pretty sure the 3650 uses the better T56 design synchros.
Andrew
Old 10-21-2018, 08:35 AM
Yes, you are correct on both, that's why I started down this road. The best thing is to continue on.
Stampede.
Old 10-21-2018, 10:21 AM
Stampede.
Please document your progress. By all accounts the 3650 is pretty strong and it could be a decent, lower cost alternative to the T56.
Andrew
Old 10-21-2018, 12:23 PM
If anyone has LS1 T56 Bellhousing that they are willing to sell for a good price or ever let me borrow one for awhile, let me know.
Thanks.
Old 10-21-2018, 12:29 PM
This is the 3650 trans that I picked up from the guy who did the Coyote swap. This the difference between a T5 and 3650 input shaft.
Stampede.
Old 10-21-2018, 01:54 PM
The difference in gear size and the synchro surface area is substantial!
Sending PM.
Andrew
Old 10-21-2018, 08:01 PM
jmd
jmd's Avatar
Arrow
Andrew
the 3650 uses brass, seen in a post above, no interchange with the T56.
Old 10-21-2018, 08:22 PM
​​​​Yes, they are brass, but if you look at the synchros on a TKO you'll see they are much smaller.
Andrew
Old 10-22-2018, 06:59 AM
Yes, please keep this thread updated! It would be great to find a budget friendly alternative to the T56. I had a 2001 GT Mustang and always loved the way that it shifted.
Old 10-22-2018, 02:29 PM
How much are T56's going for in your area, if you can find one? They are going for about $2500.00 around me.
Thanks.
Old 10-22-2018, 06:37 PM
Also, can anyone tell me how far the input shaft sticks out past the bellhousing, and the length of the t56 bellhousing is? I'm getting different dimensions when searching.
stampede
Old 10-22-2018, 07:03 PM
stampede
I can tomorrow. I have a T56 with a bellhousing sitting in the garage.
Andrew
Old 10-23-2018, 02:31 AM
tfi racing's Avatar
Sending PM.
Andrew
Well, the T5 was originally designed for use behind a 2.5 four cylinder in the AMC Spirit, it is amazing they managed to barely survive in the almost 200 hp 5.0 Mustangs and Camaros of the late eighties...
Old 12-17-2018, 06:52 PM
Well, l picked up another tr3650, came out of an 01 Cobra. It has an issue going into first, I was told it was raced a lot, the guy bought with a blown half shaft. This way l won't feel to bad tearing this one down, and it came with an aftermarket shifter. If l can sell the bellhousing and get most of my money back l would be happy. Need to make room for he tear down now.
Stampede.
Old 12-18-2018, 05:16 PM
Gray86hatch's Avatar
I have a 3650 behind a ls
Call Bob Hanlon he can set you up with a adapter to bolt it to a conventional bellhousing.
You then need a quicktime bellhousing for a chevy engine to a ford trans. Lakewood has a pilot bearing for this application.
Tim
