s10 with ls1 need new fuel pump
my ls1 now on my s10 frame needs a new fuel pump I think I need 58psi and heard there is a fuel pump that fits in the stock tank but if the pressure is greater do I need to also add a pressure regulator?
I use an automotive stealth 340lph pump in stock tank fuel gauge works still. I use ls6 intake with Holley rails but u don't have to. I use a automotive fuel pressure regulator and I have a gauge on it but u could use a digital and mount it on pillar pod. I know u can use a stock intake that had a built in fuel pressure regulator it depends on what u have already what u want and what u can afford. I prefer to have more fuel system than I need for more hp later on
There are lots of ways to skin this cat. Any decent after market pump will work great. As far as pressure goes, it depends on what intake/setup you have. You can use the truck intake./rails which will regulate it or you can use the Corvette (2000/2001ish) fuel filter that has the built in regulator in it. It is really just a matter of knowing what you have/cheapest way of doing it, and the best packaging setup for you.
