Vengeance Racing Store - Many Used Items - Some New!
Price
$1
- Location Cumming, GA, 30040, USA
We accept offers through EBay! Please click the links below for more information...SEVERAL PAGES...CHECK THEM ALL!!!
PAGE 1 -- 4th Gen F-Body or 5th & 6th Gen Camaro Specific
6TH Gen Camaro
K&N CAI for 6th Gen Camaro SS - LT1
2019 Camaro SS (Low Side) Fuel Pump Assembly
5th Gen Camaro
K&N 63-3074 Cold Air Induction
4th Gen F-Body
Steering Wheel (and air bag) for 4th Generation Pontiac Trans Am (Gray)
LS1TECH Sponsor
PAGE 2 -- C5, C6, C7 Corvette Specific
LT1 (Gen 5) Factory Pistons and Connecting Rods (150 miles)
C7 Corvette Stingray Alternator - 22868687
C7 Corvette Starter - 12619241
LT1 (Gen 5) Oil Pump - 12686436
C7 Corvette LT1 (Gen 5) Oil Pan - Wet Sump - 12679949
LT1 (Gen 5) Front Engine Cover (with Harness) - 12630095
LT1 (Gen 5) Rear Engine Cover - 12623310
C7 Corvette LT1 Oil Cooler - 12658068
C7 Z06 18% Overdrive Pulley
LT1 (Gen 5) Valve Covers (wet sump)
Mechman C6 Corvette 170 Amp Alternator
C6 Corvette Parachute Lever (bolt In)
C6 Z06 Non-Removable Roof Panel (Hard Top)
C6 Z06 Complete Torque Tube - 19132932
C6 Hood - Black
Hydratech Brake Boost System For C5 Or C6 Corvettes (#3009-BASE)
C6 Z06 Door Panels - 2007 - Ebony (with Bose)
C6 Z06 Rear Splitter - Carbon - Gloss Black (2007)
C6 Z06 Corvette Polished Alternator - 25888970
C6 Passenger Side Air Bag
C6 XM Radio Antenna
Mechman C5 Corvette, 170 Amp Alternator
C5 or C4 Corvette Headlight Module - 16523917
C5 A&A Corvette Secondary Belt Drive (single Bracket And Belt Only)
C6 Hood - Black
C6 XM Radio Antenna
LS1TECH Sponsor
PAGE 3 -- CTSV, GTO, G8, or SS Specific
CTSV Gen 3 ARH Non-Catted connection Pipes
American Racing (ARH) Catted Connection Pipes for 3rd Gen CTS-V
GM Axle 23401014 for 2016-2019 CTSV (Left Side)
GM Half Shaft/Axle 23401013 (2016-2019 CTSV) - Right Side
GM Engine / Motor Mounts CTSV Gen 3
GM Torque Converter Gen 3 CTSV (LT4) 24279498
CTSV Gen 2 Passenger Side Axle (10086584)
LS1TECH Sponsor
PAGE 4 -- LS Drivetrain (Gen 3 & Gen 4) or LT Drivetrain (Gen 5) Parts
Induction
Truck (Gen 4) Throttle Body 2008-2009 Trucks
Engine Acc.
Vengeance Racing Tall Valve Covers (LSx)
Crower LS Series All Pro LSW 12 Hurricane and Brodix LS Series Stainless Rockers
Wiseco Forged Pistons for LS Engines -27cc 4.135" Bore
GM Factory LT1 Pistons & Wrist Pins (Gen 5)
GM LS Rear Engine Cover - 12572014 (Gen 4 Engines)
Manley Chrome Moly Pushrods 7.750" .080 Wall 3/8 Dia
Comp Cams LS Camshaft 239/250 .624/.615 114+4
LS3 Style Coils With Relocation Brackets (12611424)
Carillo Connecting Rods - Custom 6.460-Inch
Gen 3 LS Valve Covers
B&M Supercooler With -12an Fittings - 70274
MAST Motorsports Rocker Stands LS7 Big Bore Heads
Vengeance Racing Camshaft for Supercharged LS7 Engines 239/254 .662/.651 115+4
Wiseco Forged Pistons, LS7, 4.125"
Vengeance Racing LT4 (Gen 5) Stage 3 VVT Camshaft (236/244 .657/.651 116LSA)
ARE LS7 Style Dry Sump Pan With 2-Stage Scavenge Pump
PAC-1324 Valve Springs
ISKY Red Zone Solid Roller Lifters - 375RHM
Morel LS Tie Bar Lifters - 5850 - Limited Travel
Wiseco Wrist Pins for LS Engines
Cometic LS7 Head Gasket - C5889-070
Comp Cams 7985 Chrome Moly Pushrods 8.050" 3/8" .080
CM Pushrods 7.225" 5/16" .080
Cometic MLS Head Gasket (Left Side)
Durabond CH-23 Cam Bearings
Injectors
None at this time
Drivetrain
Pro Torque Converter TH400
Mantic 9000 Series Flywheel - F9001H
Induction
Engine Acc.
Injectors
None at this time
Drivetrain
LS1TECH Sponsor
PAGE 5 --General LS/LT or Miscellaneous Parts (universal - not model specific)
Pirelli P-Zero Tires - Trofeo R - 305/30ZR20 (PAIR)
Gates K060990 Serpentine Belt
K&N Air Filter 33-2919 (Chevy SS or Holden Commodore)
Gates 10-rib Green Belt - K100658HD
Gates 10-Rib Green Belt - K100655HD
Racetech Aluminum Seat Brackets RTB1009M
Gates K080842 8-rib Belt
Comp Cams Magnum Chrome Moly Pushrods, 3/8", 8.200" Long (7167)
Casper's Electronics LS Coil Pack Extensions (Pair) - 109082
Magnuson 10-Rib 3.200 Diameter Supercharger Pulley
DCM Axial Electric Puller Fan - 860026
Holley 860015 102mm Sniper Throttle Body Spacer
ISKY 9968-RAD Tool Room Valve Springs
AFE Filter R24-90088 Magnumflow
LS1TECH Sponsor
LS1TECH Sponsor
Don't have that part number. This is all we have:
https://www.ebay.com/itm/Torque-Conv...IAAOSwP2Bck6qA
Induction
Engine Acc.
GM LS Valve Covers with Coil Brackets (Gen 4)
CM Pushrods 7.850” 5/16” .080
Injectors
LT1 Direct Injection Fuel Injectors - 12687709
Drivetrain
Induction
Engine Acc.
Injectors
Drivetrain
Was interested in the b&m cooler. Quick search on ebay shows you are asking more for a used one than a new one sells for.
LS1TECH Sponsor
