Windshield polishing to remove light scratches: What compound?
So there's tons of info about using compound and polish on your paint/clearcoat. Not as much about removing scratches from your windshield and it's a little confusing about what product is for what purpose, i.e. light vs med scratches.
If I wanted to remove the fine scratches on my windshield that've built up over two decades, what product should I use? I see Griot makes specific pads and a fine glass polish for their kit. I've already got a DA, so I would just need polish and pads. I also saw that Gordon Glass cerium oxide is popular.
LS1Tech Administrator
Received 1,489 Likes
I've tried a great deal of compounds and processes on glass, most are not effective for removing scratches that are anything more than super-fine, but certain products/processes can remove haze, hard water or other stains that washing and glass cleaner alone will not remove.
Most of my testing has been done on old 2-system/7" round H6024 sealed beam glass headlight bulbs. I've found that use of finer grade steel wool and metal polish shows best results in haze or very minor imperfection removal. This may not directly translate to windshield glass, especially considering that steel wool dust will get everywhere if you're doing this while the glass is still installed on the car (which isn't an issue when working with loose headlights).
Zaino Z12 Glass Polish has worked well for me as a clean-up step after the steel wool/metal polish process mentioned above for headlights. Z12 also works well to really deep clean window glass, but I can't say that it's ever removed much in the way of fine scratches. I've read about some very costly processes to remove scratches from very expensive or impossible to replace pieces of glass, but I don't think there is any cost-effective DIY way to do this. I've tried a bunch of stuff on the original glass on my '71, and the impact is very minor at best.
Quick Tip #43: How to Polish & Repair Scratched Glass
It is worth a try! If it don't work then you are left with being forced to buy a new windshield.
The Z12 product I mentioned above is very close in consistency and abrasiveness to toothpaste. It won't work on anything beyond superficial markings, but it does an excellent job of deep cleaning the glass, removing otherwise bonded contaminants, and leaving the glass with a more glossy and clear appearance.
https://www.autogeekonline.net/forum...hes-glass.html
https://www.autogeekonline.net/forum...out-glass.html
Glass polishing is indeed a thing. It is not an easy task.
I think people who've tried it with poor results don't realize that it takes a long time to polish something as hard as glass. You're not going to polish for 30 minutes and have it go from worn out to sparkling shiny new. Reading around, people usually say it'll take 2-3 hours to polish a windshield.
I use Cerium Oxide and a felt polishing wheel, It's a long process and won't remove enough material to eliminate many scratches and chips but will make an old glass look so much better. In most cases it's better to just replace the glass but if you're dealing with old cars and trucks they aren't always available or are to costly.
I believe it was a service but it became a liability issue so it is done like so many other things today. It sucks even more the only new windshield available for our cars is wavy & made poorly in China. I did the work, hope this helps op.
I use Carpro Ceriglass and am very happy with it. As mentioned already it isnt going to give you a new windsheild, but if the proper methods it will knock out alot of the fine scratches left by wipers ect. Proper methods being a glass specific buffing pad and an able DA.
Bewares, it is freaking messy. Cover up anything you care about so it doesn't get slathered.
