Jeep Grand Cherokee steering box - which PS pump?
Old 11-15-2018, 12:48 PM
1962Cat's Avatar
Default Jeep Grand Cherokee steering box - which PS pump?
Is there a better power steering pump I can use with the JGC box or will the stock one which came on my '02 LM7 work just fine? Not looking to make a race car but just want something with a nice feel to it.
Old 11-15-2018, 01:18 PM
Received 3,017 Likes on 2,348 Posts
That pump should work. Feel is more a function of the box, not the pump.
Old 11-15-2018, 02:02 PM
truckdoug's Avatar
you might consider dropping the pump pressure if you don't like how much assist it has ( a lot )
Old 11-16-2018, 03:59 PM
Project GatTagO's Avatar
Received 1,384 Likes on 873 Posts
https://www.turnone-steering.com/col...ering-fittings
Old 11-19-2018, 09:20 AM
1964SS's Avatar
Do the truck pumps have more pressure then the corvette pumps? I'm running a jeep box with LS1 corvette pump and my assist is absolutely perfect with no restriction installed.
Old 11-19-2018, 12:46 PM
truckdoug's Avatar
No idea which ones operate at what pressures, but I feel like all LS truck pumps give way too much assist. But careful how much pressure reduction you put in, it can make assist at idle rpm non existent.
Old 11-19-2018, 03:26 PM
1962Cat's Avatar
Thanks for the link. Is the truck pump considered a "canned ham" P or N type? I bought a Delco professional reman 36P1375 pump + reservoir.
Old 11-21-2018, 12:01 PM
9869KM's Avatar
This may be off topic, and i hate to seemingly hijack this, but.. I have a CPP500 series gear box and i did an LS swap, using the factory LS1 pump, and somehow my power-assist diminished, instead of increasing. I didnt change, alter, or touch anything in the steering during the swap, so same box/steering before and after, and the LS motor/pump came out of a running car that I drove and the pump worked great. So the pumps working. But how is it possible that using an LS pump my assist when down, by comparison to the SBC pump? (I've bled the sh*t out of the system several times, on several occasions). Thanks,
Kyle
Old 11-21-2018, 01:25 PM
Is it being driven the same speed as before?
