4l60e bushings
4l60e bushings
So i just rebuilt my entire car basically from the ground up. And I'm at the stage where I need to mount the trans to the car and the engine. But I need to know where all the rubber bushings are and which ones I need to get so i have new bushings on everything to install the trans.
just one mount near the output shaft
You didn't mention the vehichle this was going in so I only mentioned things pertinent to the trans alone. If you have a camaro then yes the torque arm mounts to the side of the tailhousing. Sounds like you already knew that tho
