ECS C6 Z06 Supercharger System (2200x) - Polished
Price
$4,500
- Location Cumming, GA, 30040, USA
We have a used system available here which is designed for the C6 Z06. This system produced 1050RWHP on a mild hydraulic 427 cubic inch combination and has run 189mph in the 1/2 mile.
Notes:
- Supercharger Head Unit needs the blower seal replaced
- May be missing some small fittings/misc items compared to new kit
- No fuel system included
Kit is as follows and includes a turboguard (no air intake) and the larger upgraded "race" intercooler:
ECS NOVI 1500/2200 Supercharger Kit Corvette Z06 2006-13
- Bracket and Ducting Finish Polished Brackets and Ducting
- Charge pipe has been drilled for methanol injection nozzles and modified for LME intake manifold fitment, will require revision/replacement for OEM style manifold
- C6 Model Trim Z06 Dry Sump (Oil and Steering Cooler Kits)
- Tial Blowoff Valve TiAL Q (Loud)
- Supercharger Option Novi 2200-X Polished Oil Fed 65K RPM Limit (Billet Wheel)
- Oil Feed and Drain Lines Oil Feed and Drain Line Kit
- Belt Drive System Upgrade to 8-Rib Belt Drive w/10% OD Dry Sump Balancer (Direct Drive Kit Required)
- Head Unit Pulley Size 8-Rib 300
- HPE Direct Drive Belt System HPE C6 Direct Drive System
- Harmonic Balancer Used 10% Overdrive
- Silicone Couplers Color Black
Asking $4,500 plus shipping (installation not offered) --- $7000 retail value
LS1TECH Sponsor
