H/C/I low Dyno Numbers??
I just got my 01 Camaro SS dynoed at Carolina Auto Masters. It has ls6 intake, aftermarket throttle body, ported 243 heads, ms3 cam, Lid, exhaust etc. I expected it to make at least 425 hp to the Rear wheels. The car came back at 405. Barely over 400. I've seen Cam only ls1s get to 400 rwhp. Is 405rwhp low or about right for my set up?
One thing to watch for- when someone says "cam only" that's IN the engine. They usually ALSO have a good air intake and exhaust, as you do. Actually the only thing you might have on top of all that is the ported heads. AND a lot depends on the dyno in question. They can vary ALL OVER the place. Besides all this, the real indicator of power is how it does at the strip.
I would not worry too much about the numbers. It's more about how it drives and feels. Does it do what you want?
What throttle body do you have and what exhaust?
I wouldn't take anything of mine to CAM.
is jeff still doing the tuning there ? If so that's probably another issue.
I know another guy in asheboro than can help with the tune if you feel it's off
Jeff's still there I talked to him yesterday actually.
unfortunately I can't afford to get the tune checked again....
Single or dual 2.5"? I'm assuming dual, but 2.5 single does happen. Catalytic converter(s)?
Also, which throttle body? That wasn't answered yet.
Looks like you have some local guys here that can help you!
it's a single, on the car when I bought it. Will probably upgrade down the road. Honestly not sure of the TB. Aftermarket though
Received 1,836 Likes
2.5" SINGLE exhaust? May as well stick a banana in the tail pipe, man
With a SINGLE 2.5"exhaust, I'm surprised it made even close to what it did!
Needless to say, a GOOD exhaust should be your next move, when possible. Your power numbers will skyrocket.
