oil leak still after rear main seal replacement
Old 01-17-2019, 04:56 AM
fst100's Avatar
Question oil leak still after rear main seal replacement
late last year I had a stall converter swapped out done by my mechanic and he had told me that the rear main seal was leaking and I had him replace it. fast forward a few weeks and while pulling out of my garage I noticed fresh oil spots on the ground (layed the area with cardboard to prevent staining the concrete floor). I tried looking for where the leak was coming from but wiping down the oil pan and trans pan from the grime and oil splatter makes it difficult to narrow down after driving it a few more times and putting it on jackstands again.
IF the rear main seal is fixed, and I had already replaced my oil pressure sending unit, is there any other place(s) that would cause a slow oil leak?
Old 01-17-2019, 07:59 AM
matt02ws.6's Avatar
I had an oil leak that I fixed where I originally thought was coming from the rear main but it was actually coming from the cover that the rear main sits in. There is a valley in the cover that sends oil for the lifters from one side of the engine to the other and since that is pressurized it is more prone to leakage. After putting over 25,000 miles on the car since replacing the cover seal, it is still totally dry.
Old 01-17-2019, 08:49 AM
ddnspider's Avatar
I had something similar and it was the valley cover gasket.
Old 01-17-2019, 09:32 AM
fst100's Avatar
Matt and ddnspider, are you both saying the same thing or 2 separate areas? lol
Old 01-17-2019, 09:33 AM
ddnspider's Avatar
No. He is saying the leak is from the rear cover itself which has a gasket. I am saying my leak is from the valley cover under the intake manifold.
Old 01-17-2019, 10:23 AM
LS_ELKO41's Avatar
My car is currently leaking as well near the oil filter so have been researching. It could also be the oil bypass adapter near the filter or the oil pan leaking. I am replacing my entire rear main cover which includes the rear main seal and gasket for the cover as well as my oil pan gasket. Thinking about changing out to an LS6 valley cover now since I have an 02 and won't have to clearance the block along with a new seal there too.
Old 01-17-2019, 10:32 AM
fst100's Avatar
gotcha. when I replaced my OPSU I checked around the valley cover lid and didn't see any leaks around there as well as around the OPSU. it was dry.
I would assume if the rear cover gasket was leaking my mechanic would of suggested changing that gasket instead of the rear main seal itself.
I had came across some older posts about the oil bypass adapter leaking but I haven't done an in-depth search on what's all involved.
Old 01-17-2019, 10:39 AM
LS_ELKO41's Avatar
I think the bypass adapter is just 2 10mm bolts and a small gasket that is pretty cheap iirc.
Old 01-17-2019, 11:16 AM
bammax's Avatar
Mechanics that work on old engines don't always know that the rear cover is removable. If he used a seal puller and yanked the main seal the old fashioned way it could have caused the cover gasket to fail. If he pulled the cover and knocked the seal out on the bench then he already replaced the cover gasket when he put it back together.
Old 01-17-2019, 12:59 PM
matt02ws.6's Avatar
I found this picture online and this explains is exactly where mine was leaking and the route it trickled down from.
Old 01-17-2019, 05:16 PM
bammax's Avatar
That's what you call a diagnostic nightmare. Most would change the pan gasket and wonder why it's still leaking.
Old 01-17-2019, 07:16 PM
LS1121's Avatar
When I replaced my rear main seal I bought the entire setup, he did the oil pan gasket at the same time, no more issues.
https://www.ebay.com/itm/Chevy-GMC-B...!-1:rk:15:pf:0
Old 01-17-2019, 07:25 PM
LS_ELKO41's Avatar
This is the route I am taking.
Old 01-18-2019, 10:55 AM
sjsingle1's Avatar
That circled item in the pic is the O ring on the cam sensor....common leak point
Old 02-07-2019, 02:22 PM
LilJayV10's Avatar
Some LS engines had a block porosity issue on the rear of the block. I think GM actually has a TSB on it
their fix is to RTV it IIRC. also I was not aware of the cam sensor leaking in the rear. Makes sense though
