GPI 281cc Heads Cam LS3 what do you think it will make
Was on the dyno a few weeks ago with my C6 and had a titanium retainer fail, dropped #7 intake valve and luckily it went back into the head, bent and stuck. I reached out to GPI and talked with Ryan a bit and ended up doing their 281cc heads (stock ported) milled .042 with .040 cometic gaskets, SS4 fly cut cam 236/254 .646 .637 111+4, johnson short travel lifters, manton series 5 11/32 push rods, smith brothers trunnion kit for stock rockers and BTR .660 dual platinum springs with titanium retainers. I am going to start with the mid runner fast and swap to the L.O.D. intake on the dyno for comparison. Car has electric water pump, crank scraper, tri y headers 2 x 2 1/4 x 3, 3" x pipe, flex fuel, 25% ATI pulley, no belt tensioners, 102tb, rps twin carbon/aluminum flywheel, fly cut pistons .120 and 4.10 gears. My car made 453SAE with the bolt ons and 1.85 rockers and went a best of 10.58@131. I had to swap clutches and last time I ran made 3 passes and went 10.8@128 on 93 with a splash of 110. Just curious what you guys think its capabilities will be.
I've seen some of the stuff GPI has put out on their social media.. Crazy numbers. I'd think you'll be in the 480+ rwhp range easily with the SS4. That's just a low guess.. Probably crack 500 rwhp if you already made 450 rwhp with your old setup. I know it's a different platform but I think they made like mid 550 rwhp on a H/C LT1 the other day.. Again, different platform but just cool to see those kind of number's. When do you plan to dyno?
281cc Intake runners is a lot of porting for the OEM heads and stock displacement LS3.
I would expect it to be needlessly lazy on the low end. That a problem ONLY if this car is gonna see significant street duty.
That said, I'd expect it to be strong up top......like in the 540 rwHP range through what I suspect is a M6 trans.
KW
KW
I don’t think I will be stalling in traffic by no means. It has a 26 pound rps and 4.10s. It will get to 2k instantly and from there it will make more torque then it did stock. Should not be a issue. Intake choice is for me to get through the traps making power at 135+ mph. This is my daily and it sees some track days.
Received 1,835 Likes
Time to update that sig... I'm with you guys guessing in the mid 5's. And I think it'll end up doing better with the fast vs the LOD, but we will see. With the vette weight, even if it is a bit lazy off idle, likely won't matter too much.
Whos (company) titanium retainer was it? Did it break in half or something like that or let the valve slip through?
They were BTR retainers but they had about 50k miles of service and the spring slipped through. Honestly they should have been changed but i seen no sign a fatigue when i put the roller rockers back on in November. I was in the process of doing a intake test for months so i could install my cam and my time just ran out.
Super Hulk Smash
On E85 you could touch 540. GPI has seen 540 with E85 on their small bore LS7 MAX package with a similar cam. I don't imagine the heads are that much different... but they did that with the long runner MSD and had 500+ torque numbers too. I'm surprised they didn't steer you that way as the MSD on a 376 still runs to 7400.
