Help me asap
Old 02-14-2019, 07:11 PM
UpInSmoke707's Avatar
Default Help me asap
Looking to instal a cam as my engine is out what would be a mid to agressissve cam.. Where can I learn more about the different cams and brands
Old 02-15-2019, 07:39 AM
jaxcam02's Avatar
Email Roger at Texas speed. I have a Torquer V2 can that is about in the range your looking but your going to want to talk to talk to them as they will help a lot. Just let them know what your expecting and what mods you will be planning in the future.
Old 02-15-2019, 09:26 PM
Honestly I narrowed it down to what I want to use but stuck on if I need anything with this camshaft I want to run a 228r with prc stage 2.5 ls6 heads with a 102 manifold and 102 thortle...
Old 02-16-2019, 05:51 AM
B52bombardier1's Avatar
Was your previous cam worn out? How many miles on the engine? You might . . . maybe . . . want to consider replacing the cam bearings.
Rick
Old 02-16-2019, 10:51 AM
Rick
Engine is completely stocked no cam.. I want to add a 228r cam would the prc 2.5 ls6 heads compliement the cam what cam bearing would i need for this set up ?
Old 02-16-2019, 01:10 PM
cookseyb's Avatar
You need to know the year of your engine ,there are 3 different iterations of the LS cam bearings CH-19, CH-23 and CH-25, Kinda confusing but your machine shop will (should) know..
Old 02-16-2019, 01:18 PM
ls1fan92's Avatar
I have the 288 cam with the 2.5 PRC heads. From the other posts on here, seems to be a common setup. As mentioned I would speak with TSP about your goals.. depending on your tranny will determine what other supporting mods you need (stall and cooler for auto).
Old 02-17-2019, 12:43 AM
honestly my goals just putting a cam and 228r 110 lsa is my choice with some prc heads hear it's a good gain with cam just don't what else I'll need like my tranny is stock..... thinking of a fast 92 manifold tb as well..
Old 02-19-2019, 09:52 PM
brian_rs/ss's Avatar
why 110 lsa? what tranny? do you already have long tubes? lid?
