Copper spray or dry on first time use Cometics?
Old 02-17-2019, 09:20 PM
98RedBird's Avatar
Default Copper spray or dry on first time use Cometics?
Block and heads are new. Heads were shaved and block decked, so surfaces should be pristine.
I know this had been debated endlessly, but most threads are older on this subject, and it was my understanding that Cometic had done something with their HG's to prevent the weeping issues?
Old 02-17-2019, 09:28 PM
cmysix's Avatar
just read an article , Both Cometic and Felpro say to use NOTHING. YES! they both did something, it's called multi layer steel or MLS gaskets
Old 02-17-2019, 09:55 PM
handyandy496's Avatar
only prob I have seen with these is the coating will come off in places after the first use. I have reused them without issue anyway. Should I use copper spray for better multiple use on these mls gaskets? The steel layers shift with heat and cooldown. So there's constant movement across the surfaces. Would using copper spray help or be worse reusing this kind of gasket.
Old 02-17-2019, 10:25 PM
If the mfrs. say to use nothing, that's what I would do. Why second guess them??
Old 02-18-2019, 05:11 AM
poltergeist 02's Avatar
First, I have never in my life reused head gaskets and never will. I’m not saying it wouldn’t work or hasn’t worked for people in the past but to me it’s just not worth the risk of a leak. Second, I use a light coating of copper spray on cometics to ensure a leak free installation. The quality of cometics isn’t as nice as the OEM gaskets.
Old 02-18-2019, 05:45 AM
DietCoke's Avatar
Dry first use, they have a coating on them already. Copper when you reuse.
Old 02-18-2019, 08:24 AM
branden Clark's Avatar
Dry first use, use acetone to make sure there are no oils on the block or head surface. A light copper coat when reusing.
Old 02-18-2019, 08:44 AM
KCS
KCS's Avatar
Agreed. I wouldn’t even bother spraying them on a reuse unless it was a power adder application.
Old 02-18-2019, 09:19 AM
Restricted User
JoeNova's Avatar
This. Dry the first time.
I copper spray my LS9 gaskets before putting them back on any of my cars. All boosted making decent numbers, no issues even after the 3rd re-use.
I usually won't reuse the stock gen 4 5.3 gaskets since they are cheap to replace and I can get them from most local parts stores at a moments notice.
LS9 gaskets are $100+ and are online order only for me. They're also true MLS unlike the 5.3 gaskets which have a thick graphite middle layer.
Old 02-18-2019, 11:13 AM
00pooterSS's Avatar
Dry..
Old 02-18-2019, 07:00 PM
You guys have never had issues with reusing MLS head gaskets? Serious question, I’m not trying to be ignorant.
Old 02-18-2019, 07:45 PM
01CamaroSSTx's Avatar
Received 1,786 Likes on 1,293 Posts
I've ran a MLS dry and then re-used it dry and had no issues with it sealing but the engine didn't stay together long due to a non related issue. I wasn't going to run them for a third time but I probably could have gotten away with it but it's been my understanding that you shouldn't re-use them because they've already been compressed. I was going to run the new set dry but figured why the hell not spray a light coat on them. It's certainly not going to hurt anything.
Old 02-18-2019, 07:46 PM
DietCoke's Avatar
Nope. I was on about the 15th use on my last set of cometics before I tossed them.
Old 02-19-2019, 07:17 AM
Marc 85Z28's Avatar
Dodge/Shitsubishi was plagued with head gasket leaks years ago when they went to MLS gaskets. While the initial failure was due to gasket design, the field repairs soon failed because of poor surface finish. They published a TSB for the use of copper spray on their MLS gaskets to combat the issue.
The gasket manufacturers recommendation is based upon an ideal sealing surface. IF you have a freshly machined block and head install dry per gasket manufacturer instructions. If installing the gaskets on a typical in-car head swap the copper spray is recommended to help seal voids and imperfections.
Old 02-19-2019, 12:06 PM
00pooterSS's Avatar
I remember that, we had a rash of neons come through. Still the only gasket I've used copper spray on
Old 02-19-2019, 06:04 PM
rednari2's Avatar
For what its worth, I have changed the cam on my GTO 4 times and still use the OE HGs. There's nothing wrong with them. No copper spray.
Old 02-20-2019, 07:48 PM
dixiebandit69's Avatar
I've got a question for you guys ballsy enough to reuse head gaskets: How are you cleaning them before you reinstall them?
Old 02-20-2019, 11:02 PM
rednari2's Avatar
Wire brush and sometimes brake cleaner if something is stuck to them.
Old 02-21-2019, 07:05 AM
Marc 85Z28's Avatar
I've never attempted to reuse a GM MLS head gasket like rednari2, but I've reused my Cometics a few times. Just drill out the rivets (keep the layers in order), clean with Brakleen and a quality shop rag, manually wipe the surface clean with more Brakleen using latex gloves, spray the layers and reassemble.
Don't worry about drilling the rivets as the dowel pins will keep the gaskets aligned properly.
Old 02-21-2019, 07:31 AM
Restricted User
JoeNova's Avatar
Small shallow drip tray about the size of the gasket and just barely enough acetone to soak them (8 oz or so).
Shake them around enough to loosen dirt, remove and dry with air compressor.
Ready to go.
