Cam,heads,headers, and stall install!!
Old 02-24-2019, 10:35 PM
02ls1camaroz28's Avatar
Default Cam,heads,headers, and stall install!!
Well I’m finally in the process of installing my tea ported 241s 233/239 112 lsa cam 3800 vigilante converter and headers. Wish me luck!!!!
Old 02-25-2019, 06:54 AM
Ls7colorado's Avatar
with a shop like that you should have no problem! nice!
Old 02-25-2019, 10:43 AM
LS1Tech Premium Sponsor
Aaron at SDPC's Avatar
Going to be a stout combination for sure!
__________________
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
Old 02-25-2019, 11:27 AM
Thanks the car is a base z28 non t top car with 3.73 gears. I’m hoping to run some good 11s.
Old 02-25-2019, 06:30 PM
Got the heads off everything looks well, the engine only has 98000 miles. I’m going to install new lifters, timing chain and sprockets, oil pump, arp rod bolts, and lifters.
Old 02-25-2019, 06:31 PM
Old 02-25-2019, 08:20 PM
ironmanLS1's Avatar
Originally Posted by 02ls1camaroz28
Someone went crazy with the Permatex!
Old 02-25-2019, 08:24 PM
Yeah the jacka** I bought the car from had to do some oil leak cover up it looks like but it won’t look like that when I’m finished!
Old 02-25-2019, 08:28 PM
98CayenneT/A's Avatar
The bottom of the timing cover to oil pan does need it.
Old 02-25-2019, 08:53 PM
I ant against using it just to help out with the gasket but damn use grey lol and not for an oil leak sealer!
Old 02-25-2019, 09:06 PM
Dano 00TA's Avatar
Don't you have to get the rods resized if you change rod bolts? That's the reason I didn't change mine when I had it apart. I've read both ways with more of them having to be resized.
Old 02-25-2019, 09:08 PM
Dano 00TA's Avatar
The new gaskets are so good you don't even need sealer. I only used a dab on each corner of the timing cover and have 0 leaks.
Old 02-25-2019, 09:51 PM
no not the ones I got
Old 02-25-2019, 09:57 PM
yeah that’s all I’m going to go
Old 02-26-2019, 11:28 AM
ironmanLS1's Avatar
Just a small dab on the corners works for me.
I'm jealous of that lift and overhead room. Looking forward to see what it does.
Old 02-26-2019, 11:47 AM
Thanks I appreciate it I’m going to change the cam bearings as the look a little worn. Rod and mains look good. So it would be stupid for me not to change them. Going to measure for pushrods tonight and hopefully have it back together this weekend.
Old 02-27-2019, 09:18 AM
blkbird's Avatar
I just got done with a complete rebuild - engine and trans. It has been a looooong 10 months...... Good luck!
Old 02-27-2019, 09:31 AM
Thanks I appreciate it basically the only thing not new is the rods pistons and crank. Trans is getting a z pac, beast sunshell, and a new valve body with spacer.
Old 03-03-2019, 12:33 PM
Ready
Old 03-03-2019, 06:45 PM
wannafbody's Avatar
Dang, that's shiny
