Mavns new Turbski Build . (Replacing the 416ci motor)Turbo Kit is On!
Old 02-28-2019, 09:18 PM
"I MAID THEESE"
Mavn's Avatar
Default Mavns new Turbski Build . (Replacing the 416ci motor)Turbo Kit is On!
Pulled a gen 3.5 5.3 out of the junkyard last weekend.
Gen 3.5 is a 2005 model gen 3 block, gen 4 internals, gen 4 head bolts, 24x reluctor . Perfect for some Boost .
Turbski kit will be here Monday
heres some pictures of what I got done today .
Old 03-01-2019, 12:13 AM
That_One_Person's Avatar
This should be interesting. Will the car have A/C in it when you're done?
Old 03-01-2019, 05:59 AM
Received 3,361 Likes on 2,079 Posts
Pic from front looks like alternator will be close to hood. Did you cam this engine? What headgaskets?
Old 03-01-2019, 08:51 AM
"I MAID THEESE"
Mavn's Avatar
Non A/C Kit
Old 03-01-2019, 08:54 AM
"I MAID THEESE"
Mavn's Avatar
Those are the new Ws6 Store MLS Gaskets with the Fire ring in them. my heads are old 852's with the Notch in the side.
I got a used 224/229 .600 .600 114+2 Texas speed cam for super cheap. (should work fine for what im doing right now.
Pac 1219 springs
7.400 pushrods
ARP Head Studs
Ws6 Store head gaskets
The alternator bracket is the CBR Bracket. Supposed to clear the hood well see.
Old 03-01-2019, 09:49 AM
CoreyD's Avatar
Looking forward to seeing this done! Judging by the speed of the build on your TA, you'll be done by the end of Mardi Gras lol
Old 03-01-2019, 10:05 AM
ddnspider's Avatar
Sorry to hear the old motor let go. Whose turbo kit and specs?
Old 03-01-2019, 10:37 AM
"I MAID THEESE"
Mavn's Avatar
Trying to make it to TX2k. Probably a pipe dream.. But if all my parts come in next week early enough I should be able to fire it up next weekend. and get it tuned.
Old 03-01-2019, 10:38 AM
"I MAID THEESE"
Mavn's Avatar
I purchased Soloman369's Old turbo kit off his car.
On3 Non a/c with the on3 Billet 84/75
Old 03-01-2019, 11:52 AM
ddnspider's Avatar
That should make some steam between the 5.3 and that turbo.
Old 03-01-2019, 12:26 PM
ForceFedC5's Avatar
Welcome to the Dark Side!
Old 03-01-2019, 01:13 PM
"I MAID THEESE"
Mavn's Avatar
This is round 2 haha. I built a turbo 4.8 Camaro last year and sold it when I moved.
Old 03-01-2019, 01:37 PM
ForceFedC5's Avatar
Ah.. My bad! Welcome BACK to the Dark Side! haha!
Old 03-01-2019, 02:49 PM
Kfxguy's Avatar
You dont waste no time, do you?
how did the 4.8 camaro run? My buddy has a 4.8 he said i could have. I was thinking about putting the crank in my aluminum 5.3 or 5.7 block and build a small cube turbo motor. what would a 4.8 crank be in a 5.7 block? 5.2?
Old 03-01-2019, 03:05 PM
"I MAID THEESE"
Mavn's Avatar
The 4.8 with a VS Billet 7875 made 689 rwhp on 18# Just annihilating the converter lol 23% Slip... I sold it after that. the new owner put a better converter in it and I think he said it makes around 750 ish now
Old 03-01-2019, 03:11 PM
"I MAID THEESE"
Mavn's Avatar
Old 03-01-2019, 03:20 PM
Kfxguy's Avatar
Where’s the return going? An easy option is the lower part of the timing cover. You probably should buy a two piece cover while your at it. We know how much you like to change cams. Lol.
Good numbers out the 4.8. Same turbo I have.
Old 03-01-2019, 03:21 PM
LaBLKv6Z's Avatar
Gonna run at Street car revolution?
Old 03-01-2019, 03:23 PM
"I MAID THEESE"
Mavn's Avatar
Making more Progress. Just waiting on my trans crossmember and my turbo kit. then we can try to slam it together in time for TX2k lol
Old 03-01-2019, 03:24 PM
"I MAID THEESE"
Mavn's Avatar
Im moving that weekend . so no way .. lol even if it was finished
