243 heads/ws6 store hot cam/fast 92mm intake and TB
Old 03-03-2019, 08:31 PM
392killaWs6's Avatar
Default 243 heads/ws6 store hot cam/fast 92mm intake and TB
Did the job in a week.
Installed:
hot cam
pushrods
truion kit
hv oil pump
dual valve springs
fast intake 92mm with TB
and ported 243 heads
fast fuel rails
32lbs injectors
Now I am dealing with p0300 code.
checked:
compression
coils
plugs
wires
vaccum lines
injectors
all 4 exhaust manifold pipes are hot
have not tuned yet.
Any ideas thank you..
Old 03-03-2019, 08:58 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
00pooterSS explained in another current P300 thread
"Usually with a 300 you have a common source issue. Bad fuel, low pressure, bad MAF or MAP. In other words not usually a single cylinder issue like A plug or A wire."
So I'd probably check the MAF, MAP and fuel pressure.
Hopefully 00pooterSS will see the thread or one of the others that excel at trouble shooting. Tuning would probably help.
Glad to hear the H & C is installed
Old 03-03-2019, 11:19 PM
Thanks for your .02.
Ive been reading it’s a common issue that the tune will
fix that code.
car runs great, idles at 1000
but sometime is a little shaky.
I ran it for about 20 miles and
it was more explosive after the 20 miles.
Hopefully tune helps.
In Coachella, Ca (SoCal)
any ideas on good LS tunners in the area.
Old 03-03-2019, 11:21 PM
Fuel pressure was 40-60 on gauge..
Old 03-04-2019, 01:21 AM
Received 3,018 Likes on 2,349 Posts
It should be close to 60 at all times.
Old 03-04-2019, 04:53 AM
fst100's Avatar
i don't know how aggressive the hot cam is but generally without a tune, after a cam swap the misfire code 0300 would turn on due to the cam profile. once tuned and the dtc is turned to ready but off, the light will be off for that code.
Old 03-04-2019, 06:49 AM
z28241's Avatar
I would not drive that until it gets a tune, especially after swapping injectors and cam.
Old 03-04-2019, 12:52 PM
What I mean by exploded is
it ran super good when floored it..
Old 03-04-2019, 12:53 PM
*explosive
Old 03-04-2019, 02:28 PM
00pooterSS's Avatar
On it, lol.
In this case his single source issue is the cam with overlap that is literally causing a misfire at idle on all cylinders.
Do not chase the P0300 untuned with a cam. The cam is causing it and the tuner should turn the 300 code off.
BTW, I assume that cam is a bit of a lumpy idle cam, if so it's likely 100% of your issue.
To further explain what you mentioned about my explanation on the code.. The P0300 code is "random multiple misfire" so you're looking for something that affects all cylinders. Fuel, cam, timing, MAP, MAF, CKP sensor, CMP sensor, fuel pump.. things of that nature.
Old 03-04-2019, 02:34 PM
...and the untuned cam would effect all cylinders
Realized the WS6 Store Hotcam is aggressive
Old 03-04-2019, 09:57 PM
Thank you guys for your .02
anyone know what the runner will do to fix that?
Old 03-04-2019, 10:06 PM
I'm not sure it would do anything. I haven't seen different runner lengths smooth a cam lope yet, and that's what's causing the problem. A cam loping is an intermittent miss on all cylinders.
Old 03-05-2019, 12:13 AM
*tunner
Old 03-05-2019, 12:14 AM
I meant the guy that will be doing the tune.
dam auto correct
Old 03-05-2019, 11:47 AM
Tuner..... only one "N". That's where auto correct got ya.
Old 03-05-2019, 12:11 PM
00pooterSS's Avatar
disable the p0300
Old 03-05-2019, 07:00 PM
How do you post a profile pic?
ive been looking all over the website..
Old 03-05-2019, 08:31 PM
00pooterSS's Avatar
Top right corner click on your name
Select User CP
On the left scroll down to edit avatar, click it and take it from there.
Old 03-05-2019, 08:32 PM
00pooterSS's Avatar
Yuuuuuup.
