LED turn signals/ digital flasher behaving strangely
I'm having some annoying lighting issues with a 94 Camaro I picked up a couple months ago.
The front turn signals had been changed out for clear housings and LEDs. Essentially they work when they want to, or about half the time. The flasher thats currently installed is the CF12ANL-01. I did some digging and can't find if its supposed to make a clicking sound because this one doesn't when the signals are working.
Hazards work fine, out of curiosity I tried an OEM flasher and the lights stayed lit without blinking. It seems like the flasher I have is only for full LED setups? Why does it only work half the time? Any suggestions are appreciated.
That's not going to make a clicking sound since it's electronic. No relay inside to do the clicking. That said.... you'll most likely fix your issues, either by getting a flasher that also has a third ground hookup, or adding some load resistors the the LED harnesses. Usually, you can find them prewires so it would be plug and play. Something like this >
That's not going to make a clicking sound since it's electronic. No relay inside to do the clicking. That said.... you'll most likely fix your issues, either by getting a flasher that also has a third ground hookup, or adding some load resistors the the LED harnesses. Usually, you can find them prewires so it would be plug and play. Something like this > https://www.amazon.com/HUIQIAODS-744.../dp/B07K2TK855
I am thinking of just going full LED in the rear since I have this flasher already. If I order the bulbs, I'm assuming it will fix this current issue and I'll need another flasher for the hazards too right?
Edit: And just to check/ confirm, I've read that an EL12 flasher may work in the case of not having rear LEDs? Something like this..
https://www.rockauto.com/en/moreinfo...=1324312&jsn=7
I bought the car this way. Still looking for a proper list of bulbs I can use to swap the whole rear end out.
Can anyone confirm if I can use the same electronic flasher for the hazards since I'm assuming I'll have to change that too if I go full LED? Thanks
yeah just get two No Load flashers for the turns and hazards..
check out Retrofit Source for the LED bulbs... the contacts on those (Profile Peak) are nice and thick and wont be easily broken or corroded like every other cheap LED bulb
https://www.theretrofitsource.com/le...ior-bulbs.html
Thanks guys. For the time being I ordered an EL-12 flasher to get the signals working, according to my research it should work with a part LED setup.
Priced out the full LED tail light treatment at superbrightleds and it looks like it comes out to close to $100 with bulbs and another flasher. Not cost prohibitive but I'm worried about having potential issues, have read a few accounts of people having problems after going full LED. Will upgrade after I get the current setup working, this is a beater I use often so I need the signals working.
https://ls1tech.com/forums/stereo-el...l#post19340485
I am pretty sure the wiring is the same for the earlier models. But I went full LEDs in my 02 and all works fine. I posted feedback in this thread with the flasher I got. Everything is still working fine til this day.
