Gen 4 connecting rod bolts
Old 03-17-2019, 07:10 PM
Buschlight's Avatar
Default Gen 4 connecting rod bolts
Hey all, I tore my 5.3 apart to find that it was rebuilt. Anyway I had to do some gapping of the rings since they were way too tight. Well I'm reusing my connecting rod bolts and am wondering what to torque them to? I dont think the angle method is relevant when reusing the bolt but maybe I'm wrong. I was thinking a pass of 15 flbs and take it to 50? Seen a few YouTube videos. Just wondering how many people are doing that. They are gen 4 rods too by the way..
Old 03-17-2019, 08:23 PM
Look up the std spec and follow it. Not rocket science....
Old 03-18-2019, 02:19 PM
ColeGTO's Avatar
Rod bolts can be reused, and the factory torque specs should be followed using the specified lube on the threads and under the head. The rod bolts are not the same as the other "torque to yield" fasteners on the engine. While the rod bolts have a "torque angle" requirement, that is not the same a "torque to yield".
The manual calls for 15 lbft + 85 degrees, use that.
Cole
Old 03-18-2019, 08:20 PM
00pooterSS's Avatar
You can reuse them. They are torque to angle and not torque to yield.
Follow the OE tq, don't try to outsmart the engineers that tested the bolts.
Like Cole said, 15 ft lb + 85 degrees
Old 03-22-2019, 09:05 AM
rednari2's Avatar
Correct, tighten the rod bolts to 15 lbs and then tighten further about a quarter of a turn. The bolts interchange OK, but the caps won't. Each cap is fracture cut for each rod. So do not interchange rod caps.
Old 03-22-2019, 07:40 PM
vorteciroc's Avatar
Received 1,204 Likes on 844 Posts
Gen III connecting rod bolts are spec'd @ 15.00 Ft/Lbs + 60.00 degrees.
Gen IV connecting rod bolts are spec'd @ 15.00 Ft/Lbs + 75.00 degrees.
These torque values are as such when properly lubricated with some variant of 30 weight engine oil.
The threads and underside of the bolt head are to be lubricated.
Note: Aftermarket fasteners will usually have a unique or special torque specification... Such as ARP connecting rod bolts.
ARP fasteners will also include a specialized lubricant that helps to improve the uniformity and accuracy or the bolt torque.
Pay special attention to wither or not a torque spec is dry or lubricated... and as such, with what lubricant.
For future engine building; a connecting rod bolt stretch gauge would be ideal to use or to own... as connecting rod bolts are one of the most stressed parts in these engines.
Inexpensive models can be found for close to $50.00 to $70.00 from many retailers.
Old 03-22-2019, 10:07 PM
LS1Tech Premium Sponsor
tech@WS6store's Avatar
This is the second or third post youve come in and gave wrong info for. Im not sure why or how but seriously its not good.
Everyone else in this thread is correct though.
Old 03-22-2019, 10:43 PM
vorteciroc's Avatar
OMG!
Did I type a 7 instead of an 8 ???
Wow! you must be God!
Have a nice day :-)
Old 03-22-2019, 10:48 PM
Maybe you should not be so dramatic...amongst other things. Also taking his name in vain like that is a bit much. You seem like too much of a perfectionist to miss a 7 for an 8 also.
Im no God, but i do assemble engines, design parts, and sell them, give tech support on many platforms for a living also as well as help sponsor this forum you are using to pass on bad info.
I come down hard on bad info because any google search could bring this up and then people will see what you say and claim and even though its bad or wrong, will recycle it for one reason or another.
Old 03-22-2019, 11:04 PM
vorteciroc's Avatar
I have no complaint about coming down hard on bad info.
I would do the same thing, but usually in a more supportive way.
The issue here is we can't agree on the "BAD information"
I say it is your info...
and you say it's my info...
Old 03-23-2019, 04:37 AM
Buschlight's Avatar
15ft lbs + a quarter turn seems a lot like 50 ft lbs
....lol
Old 03-23-2019, 07:38 AM
FormulaBoat's Avatar
Just do what the factory manual says. I’ve put wrong info to print before. I’ll just then go back and quickly change or delete it so it does not travel.
Old 03-23-2019, 10:05 AM
YOUR info was the bad info! Factory (who you worked for...) says 15 plus 85 degrees, which is MORE than you stated above. Do you know more than your former employer?
Old 03-23-2019, 03:38 PM
Received 3,368 Likes on 2,085 Posts
....lol
I’ve done the legwork and it’s 47-48 ft. Lbs. That’s the value I use for Oem gen 4 rod bolts, but I’d rather not post that up as an answer to someone’s question, because the bolt isn’t designed for that. It’s designed for 15 ft. Lbs. + 85 degrees.
Old 03-23-2019, 03:43 PM
The torquing then torquing to yield is a good practice to help stretch the bolt also vs just torquing once. Thats the whole idea also and basically the definition.
Old 03-23-2019, 04:10 PM
Agreed. Always torque bolts in multiple steps.
Old 03-24-2019, 10:14 AM
00pooterSS's Avatar
You're the only person in the thread that agrees with you, everyone else agrees with him, and you still think you're right???
