CTS-V 2nd gen rear brake converiosn on 98 trans am?
Who has converted all 4 corners to a CTS-V 2nd gen brakes? The donor car was a 2011 CTS-V. The customers car is a 98 trans am with 18" wheels. Its pretty straight forward on the front drilling the caliper holes out on the spindle and using the larger bolts and using Z06 brake rotors and new brake hoses. No problem there. Now the rear this looks to be an issue. The caliper bolt holes do not even line up. I have done some searching and there is a company making a new bracket and backing plate that you pull the axles and slide these on and put the axles back in. Is this the only way? What company's are out there that offer such brackets? I found one kit that is $550 or something crazy. Any leads on a cheaper alternative? Who has done this upgrade?
I used the Big Brake Upgrade brackets on my '57, had the 12 bolt built with F-body 7900 flanges. Pretty straight forward install as long as the axles can come out, and the brackets were top notch. I realize it's not apples to apples, but I'm using his bracket on an F-body equivalent axle flange with success.
