One Fast ZO6 Garage Sale - Something For Everybody
For SaleEngine - Internals
Price
$30• OBO
- Location Austin, TX, 78748, USA
- Condition Used
-1. factory plastic intake manifold bolt kit $23
0. LS2 LS3 LS7 and Gen 4 5.3 6.0 6.2 timing cover and sensor $40
1. LS1 throttle position sensor $10
2. LS1 idle air control valve $15
3. LS1 map sensor $10
4. LS1 water pump bolts $10
5. LS1 cam retaining plate and bolts $10
6. LS1 Camaro power steering bracket $25
7. LS1 Camaro motor mount and motor mount stand bolts $15
8. LS1 gen 3 knock sensors SOLD
9. LS1 bell housing bolts $15
10. LS1 Camaro Firebird 4 l60e automatic transmission cable $25
11. LS1 gen 3 cam position sensor $18
12. LS1 gen 3 24 tooth crank position sensor SOLD
13. new Harris Speed Works nitrous plate with jets fits all 78 mm throttle bodies $125
14. LS2 LS3 LS7 Gen 4 5.3 Valley cover plate and sensor with gasket SOLD
15. LS2 LS3 LS7 LS1 rear cover $15
16. 24 tooth Factory LS1 reluctor wheel $20
17. LS3 LS7 Gen 4 5.3 58 tooth 4-pole timing cover and sensor $40
18. LS2 timing gear $10
19. LS3 factory camshaft, timing gear and bolt $100 GREAT FOR 5.3 ENGINES!
20. LS1 factory throttle body for Camaro or truck. 70 mm. This is a throttle by cable. Comes with throttle position sensor and idle air control valve. $65 shipped.
All parts in good working condition. can combine parts for better pricing in cheaper shipping. Basically the more you buy the cheaper it is.
