Repinning PCM help
Old 03-25-2019, 07:20 PM
StankyWankyKime's Avatar
Default Repinning PCM help
I have a 12576106 Blue/Green pcm that i want to use on a Drive by cable Blue/Red Harness for an Ls1. How do i go about repinning the pcm to make it work with the harness? I have the pcm tuned, just dont know where to start on repinning it.
Any help would be useful.
Old 03-25-2019, 07:47 PM
Most of your post printed in a color that is very hard to see. if you re-send it in a dark print it would be better.
Old 03-25-2019, 08:08 PM
—— Sorry about that, not too sure why that happened.
Old 03-25-2019, 08:22 PM
Someone should pop in here to help you. Thanks for re-posting! VERY visible now
Old 03-25-2019, 08:35 PM
I appreciate the notice.
Old 03-26-2019, 06:50 AM
ChopperDoc's Avatar
Couldn't find a pinout but I found this:
http://lt1swap.com/cable_conversion.htm
Old 04-03-2019, 07:59 PM
rpturbo's Avatar
Why not just use the 2004 van ecm? It is blue/green, has iac drivers in it. It is drive by cable, and supports anything you can throw at it segment swap wise. The 04 corvette has a 6spd segment, and many vans had 4l60 others 4l80. As far as boost, it has 2 and 3 bar, a SD setup, and flex fuel. It's THE os to use IMO
