84 c10 Turbo 5.3
Not in order but you can see the issue I had with the cheap fuel rails. One hole lined up on each side but the other was a bit off. I just cut the bracket, flipped the piece I cut over and welded it back. It worked decent.
decided to use a bulkhead fitting on the timing cover for the drain. Once I drilled the hole and test fit I had a bit of interference with a bolt holding the oil pump on. You can see where it was barely hitting. So I ground the nut down and it cleared. I got lucky on that one for sure.
the bracket that came with the oil cooler wasn't going to work to mount the fan so I came up with something else. Painted the valve covers ,timing chain cover and lifter cover with wrinkle black. Knock sensor grommets will be here tomorrow and I'll install the cover back.
