Which MAF with 24x?
Old 05-19-2019, 07:47 PM
ElkySS's Avatar
Default Which MAF with 24x?
The new motor I'm building is going to max out the stock MAF. Since I'm going EFI Connection 24x, I'm considering either a truck 85mm, an LS3 card type, or the redesigned stock replacement. The card type would be an easier install if I get a 3.5in pipe to mount it in but I'm curious what others have to say about this.
The following 2 users liked this post by ElkySS:
cino (06-02-2020), Stokes1114 (05-10-2020)
Old 05-20-2019, 01:04 PM
MuhThugga's Avatar
I'd go with the card type, personally.
Old 05-20-2019, 01:26 PM
ElkySS's Avatar
Why's that?
Old 05-20-2019, 02:11 PM
MuhThugga's Avatar
It's much more versatile and affords you the ability to go with larger piping down the line without needing to replace the entire sensor.
It requires different mapping than the 3 and 5-wire MAFs, but that really isn't a big deal. It's just a different table that needs to be loaded.
Old 05-21-2019, 07:01 AM
moehorsepower's Avatar
If you know how to tune you wont need another MAF, Ive been running a stock MAF since 97, forced induction up to 15lbs
Old 05-21-2019, 12:06 PM
Man-Crush Warning
Shownomercy's Avatar
Not saying you are wrong in anyway, but, GM moved ahead with their MAF style/sizing for a reason and might as well take advantage of the new stuff with the "new" 0411 PCM.
Ty McBride (07-05-2020)
Old 05-21-2019, 04:04 PM
Agree 100%, technology continues to move on for a reason, Just like I have been using a stock pcm for boost since 97 when it was said it could not be done, but I can see going 24x or FAST or Holley for an upgrade.
Old 05-22-2019, 04:05 PM
ElkySS's Avatar
I was originally planning on just sticking with my msd opti for this build but I got a great deal on this 24x kit. I just couldn't pass it up. Just trying to make the most out of it now
Old 06-22-2019, 07:22 AM
AeroSS's Avatar
What year/s is the card type MAF in? I need a part number, and want to do the same thing. Buying a mount and welding it in the tube is the route I'm looking at going.
Edit. I guess I hadn't had enough coffee yet!! I answered my own question, so here is the answer if anyone else is looking in the future:
RockAuto says ACDELCO Part # 2134222 (GM part #15865791) is the MAF is the same for all these vehicles:
CADILLAC SRX 2008
CADILLAC STS 2008
CHEVROLET COLORADO LS 2008
CHEVROLET COLORADO LT 2008
CHEVROLET COLORADO WT 2008
CHEVROLET CORVETTE 2008
CHEVROLET CORVETTE 427 LIMITED EDITION Z06 2008
CHEVROLET CORVETTE Z06 2008
CHEVROLET HHR LS (2006 - 2008)
CHEVROLET HHR LS PANEL 2008
CHEVROLET HHR LT (2006 - 2008)
CHEVROLET HHR LT PANEL 2008
CHEVROLET MALIBU HYBRID 2008
CHEVROLET MALIBU LS 2008
CHEVROLET MALIBU LT 2008
CHEVROLET TRAILBLAZER 2008
CHEVROLET TRAILBLAZER LT 2008
GMC CANYON SL 2008
GMC CANYON SLE 2008
GMC CANYON SLT 2008
GMC CANYON WT 2008
GMC ENVOY SLE 2008
GMC ENVOY SLT 2008
HUMMER H3 2008
HUMMER H3 ALPHA 2008
HUMMER H3 X 2008
ISUZU ASCENDER S 2008
ISUZU I-370 LS 2008
PONTIAC G6 (2006 - 2008)
PONTIAC SOLSTICE (2007 - 2008)
PONTIAC SOLSTICE GXP (2007 - 2008)
SATURN AURA GREEN LINE (2007 - 2008)
SATURN AURA XE 2008
SATURN SKY (2007 - 2008)
SATURN SKY RED LINE (2007 - 2008)
Old 06-24-2019, 10:13 PM
CamOnlyJabroni's Avatar
I’m going to use a LS3/LS7 card style maf in a 3.5” tube. I was maxing out a 85mm maf using the factory pcm. My TorqueHead conversion will be here Wednesday
Old 05-10-2020, 02:08 PM
nsaness's Avatar
Sorry, I am resurrecting this year dead thread. I have searched, and this seems to be specifically what I am looking for. I am rebuilding my LT1 Impala with a Torqhead 24X and a new RMCR stage 2 (V2hd Ti-trim) centrifugal:
I am totally ignorant to tuning and the 24X, and I have no idea what the tuner will need once I get that far (I am probably 3 months away from finishing my build). Does it make sense for me to get the GM part number 15865791 MAF sensor installed for the tuner, or are there other choices that work better?
Thank you for anything you can teach me.
Mike
Old 06-01-2020, 08:39 PM
nsaness's Avatar
I’m going with a speed density tune.
Old 06-02-2020, 01:13 PM
Rob94hawk's Avatar
How is this 'card' stay MAF mounted?
Old 06-02-2020, 02:15 PM
chadtn's Avatar
I don't believe you use a mass air sensor at all on a speed density setup.
Chad
Old 06-02-2020, 07:00 PM
Man-Crush Warning
Weld in a bung that the card will fasten to
Ruken (07-05-2020)
Old 06-02-2020, 07:14 PM
Here is my setup.
The following 2 users liked this post by CamOnlyJabroni:
nsaness (06-02-2020), Ruken (07-05-2020)
Old 06-02-2020, 08:11 PM
nsaness's Avatar
Smile
Chad
Thank you. That is correct, upon (learning, then) weighing the options, I skipped the MAF and am going speed density.
Old 06-03-2020, 01:42 PM
TravisA's Avatar
That setup looks good! Is that 3.5 or 4” with the card setup?
I have a 24x setup on a 385 LT1 and i’m in the beginning stages of speed density tune. Debating on running a MAF.
Old 06-26-2020, 11:50 PM
Fast355's Avatar
Run the MAF....Will give you a better tune than speed density only.
I have a 4" MAF housing and a LS3/LS7 cartidge MAF on my L31 based 383 Express van. Full 4" air intake from the bonnet on the throttle body to the OEM air box. Spectre housing with a 4" 6:1 screen I picked up to smooth the flow. 1200cfm 4bbl throttle body on a marine dual plane MPI intake.
Old 06-28-2020, 06:24 AM
StealthFormula's Avatar
Eh, to each their own. From personal experience with both, I prefer speed density. The key is a quality tune done by someone capable of doing it right. I’ve realized benefits with no drawbacks. Not for everyone i.e. not appropriate for the guy/girl who may drive a vehicle in extreme elevation changes but most of us aren’t.
nsaness (06-28-2020)
Quick Reply: Which MAF with 24x?
