Interesting sound from rear
Old 05-28-2019, 05:35 PM
Tyler Dietzenbach's Avatar
Default Interesting sound from rear
I know sounds have been beaten to literal death on here, but this is different/unique. I have a 1998 Z28. 44K miles. A4 tranny. Performance rear option. Everything is original (to my knowledge) I've had the car since about 2011. Its done this since day 1. So what happens is, is that I hear a popping sound in the rear. There are only 2 scenarios that it occurs. First, it makes the sound when the car is bouncing, not when hitting a bump, more so when hitting dips or humps in the road. The other scenario happens when exiting the vehicle. It is quite audible. Sounds like a heavy spring type pop. Almost 50/50 on if it happens when exiting the car.
Old 05-28-2019, 05:37 PM
I will also add that it sounds like its the passenger side rear only.
Old 05-29-2019, 06:32 PM
GHall8788's Avatar
are your springs sitting correctly on the top?
Old 06-01-2019, 10:12 PM
I'm going to have to look at those tomorrow. Sorry for the late reply. Been busy.
Old 06-04-2019, 09:38 AM
Springs look perfectly fine on top.
Old 06-05-2019, 05:54 PM
Any other theories?
Old 06-06-2019, 04:13 PM
I've tried bouncing the car by pushing down on it, and also from underneath pushing up and bouncing it. I can't replicate it at all
Old 06-07-2019, 12:31 PM
Daily Bump
Old 06-09-2019, 06:46 PM
Bump.
Old 06-11-2019, 10:03 PM
Bump. Had the problem for roughly a decade.. seems a little worse this year. Basically does it on bumps now too.
Old 06-14-2019, 04:11 PM
Do these look normal? To me they don't. Could that cause the sound im hearing?
Old 06-16-2019, 02:16 AM
sjsingle1's Avatar
the bottom bushing is def shot
stock suspension ? LOTS of rubber that needs to be checked to make sure its not dry rotted and crack......which it is pro anyway and needs replacing
Old 06-16-2019, 11:27 AM
Yes. Everything is stock and original except for a lid, tires, battery, and SSRA.
Old 06-30-2019, 07:56 PM
I jacked the car up on each side and re-lubed the entire brake system (not because of the sound). Ever since I jacked it up and did that, the sound has totally disappeared and not come back. 500 miles later. No clue why...
Old 08-19-2019, 05:55 PM
The pingy spring sound came back today after driving over some really rough roads
Old 08-19-2019, 06:46 PM
pdxmotorhead's Avatar
lube the sway bar bushings,, they can be sticky and if the end links are worn the bar will make a pop/thump noise ?
Happens on my Jeep .. So wild guess.. I also had a noise that sounds similar caused by a cracked shock mount..
