stock replacement engine question 02' trans am.....
Old 06-19-2019, 01:04 AM
SkWiDsTyLe321's Avatar
Default stock replacement engine question 02' trans am.....
was just wondering if a 99-04 corvette ls1 will fit with no problems or modifications into my 02 trans am ? i just find way more of these year vette engines than trans am or camaro.
with a 99 or 00 will the ls1 manifold vs. the ls6 throw a code or hamper anything ? just doing a pull out/drop in - no upgrades or anything.
Old 06-19-2019, 01:26 AM
98CayenneT/A's Avatar
Swap away
Old 06-19-2019, 10:04 AM
It's like for like. Why do you even ask unless you know NOTHING about what you are dealing with??
Old 06-19-2019, 10:32 AM
SLP IROC-Z's Avatar
I say upgrade and find yourself a nice ls6 dropout
Old 06-19-2019, 11:29 AM
NHRATA01's Avatar
I'm not in the know enough about tuning myself, but if he's really not swapping parts, any risk the 26 vs 28 pound injectors might throw off the tune a bit?
Old 06-19-2019, 03:23 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
Agreed
Old 06-19-2019, 04:42 PM
Enigma540's Avatar
I may be mistaken, but isn't the vette ls6 intake missing the throttle cable bracket bolt holes? I've seen a few just drill them and and add nuts behind to hold it, since even drilled it's still missing the brass inserts.
Old 06-20-2019, 10:03 PM
https://sacramento.craigslist.org/pt...911400022.html - looking at this 99 c5, but the alternator is at the top vs. how its configured on the bottom in the 02' trans am ls1.-- would that be the only difference and will it still fit fine like that ?
Old 06-20-2019, 10:06 PM
If you're worried about it change it over to your accessory setup. They're all interchangeable
